Crawlspace Insulation Under Porch - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-11-2009, 12:27 PM   #1
Wounded Mathematician
shtoink's Avatar
crawlspace insulation under porch
Hi
I have just finished insulating the concrete walls of my 5 ft high crawlspace with rigid foamboard. The crawlspace is heated by a small electric baseboard heater to prevent pipe freezing. One front corner of the crawlspace is below a 6' x 15' covered porch. The porch flooring is 1x4 tongue & groove.
What is the best way to insulate the crawlspace ceiling below the porch?
I have enough leftover foamboard insulation to cover the area.
Should I use it? If so, what is the best way to attach it?
Do I need vapour barrier?
The house is on an island off the coast of BC, Canada.
The poets have been mysteriously silent on the subject of cheese.
G.K. Chesterton
shtoink is offline   Reply With Quote
Old 11-11-2009, 04:05 PM   #2
Rewards Points: 5,336
I wouldn't insulate under the porch. If cold air is coming in, I would block the opening and insulate that.
Ron
Old 11-11-2009, 04:19 PM   #3
shtoink's Avatar
All openings, nooks and crannies where cold air can get in have been sealed and covered. So you're saying that there would be insignificant heat loss up through the 1" thick porch flooring without any insulation?
G.K. Chesterton
Old 11-11-2009, 05:42 PM   #4
is the porch a conditioned space, protected from the weather?
Old 11-11-2009, 09:04 PM   #5
shtoink's Avatar
The porch is covered by the roof but is open to the elements. See photo:
G.K. Chesterton
Old 11-11-2009, 09:08 PM   #6
What I'm saying is that depending on the layout, you might be able to close off the porch section instead of insulating the porch joists. If you post a picture, I could get an understanding of the setup.
You should look into the device that wraps the pipes and produces heat. Having an electic heater running all the time will be costly.
Ron
Old 11-11-2009, 10:33 PM   #7
shtoink's Avatar
I have no photo showing inside the crawlspace. I could probably close off that section of the crawlspace with some framing tied into one of the pony walls, but I simply don't have time to do that before winter.
I do plan to use heat tape on the water lines too.
G.K. Chesterton
Old 11-12-2009, 05:20 AM   #8
remember the rules: if it is insulated it ought to have a vapor barrier, but I agree whole heartedly with the fellow who recomended wrapping the pipes, after all an exterior porch is non- living space. Remember insulation will hold moisture, if it's getting wet from above or below get rid of it, you don't need an ice blanket around yer pipes
Timberratt is offline   Reply With Quote
Old 11-12-2009, 07:50 AM   #9
whatever you put under porch decking will get wet
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Crawlspace insulation ekulrenlig HVAC 2 10-05-2009 05:30 AM
crawlspace insulation md9693 General DIY Discussions 5 01-22-2009 10:30 PM
Crawlspace insulation reccomendation Gus Building & Construction 3 12-29-2007 11:23 AM
