Crawlspace Foundation Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-04-2009, 07:51 PM   #1
crawlspace foundation question
My house has two crawlspaces with no access into the second, smaller one. We have a problem with moisture in the larger, accessible crawlspace, and since the smaller one is on lower ground than the larger one, I think we should assume it has a problem with moisture, too.
We'd like to put a hole in the foundation wall separating the two crawlspaces. The hole needs to be large enough to look through to see what's up on the other side. Can I just start chiseling out a cinder block or two without worrying about foundation integrity?
Thank you to anyone who has some sage words of advice.
barbw is offline   Reply With Quote
Old 12-05-2009, 09:48 AM   #2
Remodeling Contractor
you can remove a block or two but you need to add a header over this opening to maintain the integrity of the structure.
Old 12-05-2009, 10:08 AM   #3
Thank you!
I have a basement systems guy telling me we can put a hole big enough for a worker to crawl through. It doesn't sound like it. Intuitively, I didn't think so. Thank you for the reply.
Old 12-05-2009, 10:14 AM   #4
you can make it this big. Just add a 3" X 5" steel lintel for the header at top. Saw out the space needed for the steel and fill the gap above the steel with non-expanding grout. Also wrap the steel with window flashing tape to prevent rust from condensation.
Old 12-05-2009, 11:31 AM   #5
thanks again
This should be interesting. Thank you again for the guidance!
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 08:39 AM
New addition foundation question ccevans6 Building & Construction 3 10-12-2007 11:40 AM
musty crawlspace svmaine Building & Construction 2 09-03-2007 03:53 PM
crawlspace exposed to outside and damp djbauda Building & Construction 5 07-30-2007 07:49 AM
Foundation movement question kelly001 Building & Construction 5 10-02-2006 06:09 AM
