Crawlspace Encapsulation Complication - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-16-2014, 09:07 PM   #1
Restoration professional
Rewards Points: 294
Crawlspace encapsulation complication
I'm going to encapsulate a 14' x 28' crawlspace in a 1920s house, next to a basement. It's adjacent to a basement, so I'm going to insulate the basement. CMU wall separates the crawlspace from the basement, waist-high, full of dirt. 2x4s run horizontal on top of the CMU wall, and 4x4s go up. In the pictures, you see plywood sheathing separates the basement from crawlspace, this will be removed. For the wall closest to the picture, where and how do I attach the vapor barrier? All pictures are of the same area, just taken closer in, or further away.
Crawlspace encapsulation complication-screen-shot-2014-12-16-8.04.25-pm.jpg   Crawlspace encapsulation complication-screen-shot-2014-12-16-8.04.13-pm.jpg   Crawlspace encapsulation complication-screen-shot-2014-12-16-8.03.53-pm.jpg   Crawlspace encapsulation complication-screen-shot-2014-12-16-8.03.37-pm.jpg
halliwellc is offline   Reply With Quote
Old 12-17-2014, 08:37 AM   #2
Rewards Points: 4,583
Will you have access to that space when done.?
ron45 is offline   Reply With Quote
Old 12-17-2014, 08:21 PM   #3
Rewards Points: 294
Yes. The plywood half-walls that separate the basement from the crawlspace will all be removed (one has already been removed, and that is the area I photographed) and the waist-high crawlspace will be used for storage. The plywood and crawlspace does some zigzagging, and that's why you see plywood in the second picture.
Crawlspace treatment for older home? Pittsville Building & Construction 3 06-02-2014 10:28 PM
Crawlspace Encapsulation and HVAC amg1950 HVAC 0 10-22-2013 09:11 PM
crawlspace slab voids, basement water geoffmiller Building & Construction 0 11-25-2011 10:01 AM
Crawlspace Moisture - Serious Problem PaoloM General DIY Discussions 11 12-15-2009 02:35 PM
crawlspace exposed to outside and damp djbauda Building & Construction 5 07-30-2007 08:49 AM
