Crawlspace Clearance Under The Beams And Joists ? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-02-2007, 08:59 AM   #1
crawlspace clearance under the beams and joists ?
Is 12" of clearance under the beams and 18" under the joists requiered ?
can I excavate to the bottom of the footer
chuckgo is offline   Reply With Quote
Old 09-02-2007, 10:06 AM   #2
Rewards Points: 1,450
I know it is 12" and 18" here. Which is not nearly enough by any means....
As to the other question, I have no idea.
ktkelly is offline   Reply With Quote
Old 09-02-2007, 11:24 PM   #3
Rewards Points: 5,336
If your asking a code question, you need to contact your local building department. If it's something else, it would help to give an overview of the project and what you're trying to accomplish.
Ron
Old 09-03-2007, 04:45 PM   #4
digging out a crawlspace
Ron
Thanks, Just a general question.
When digging out a crawlspace, I have learned IRC allows to the bottom of the footer, thenn maintain a 45 degree slope away for anything deeper in the middle.
Old 09-07-2007, 02:49 AM   #5
renovations
Around here at least you can't excavate inside the foundation below the level of the drain tile on the outside of the footing, or water will try to fill the excavation rather than flowing through the tile.
Just because one part of the code says you can do something, doesn't mean that other parts don't expressly forbid it!!
Bonus is offline   Reply With Quote
sistering 2x6 ceiling joists nelsonC Building & Construction 23 11-21-2008 11:01 AM
Adding outdoor wiring from crawlspace MusicMan_234 Electrical 2 06-25-2007 09:57 PM
