Old 05-28-2011, 06:41 PM   #1
Question
Crawlspace
I have a 14' X 16' dirt/clay crawl space under my kitchen I can feel allot of moisture coming from the basement. its about 50 inches in height so I can crawl around in it. what should i do to seal up the ground to prevent the moisture coming from there. I was thinking of lay a 6mil roll of vapor barrier on the ground and walls and using buckets to put 2" of small gravel on top of the barrier.
any other ideas I can use?
Thanks Level
Level is offline   Reply With Quote
Old 05-28-2011, 09:56 PM   #2
Crawlspace
you've got it. use non-hardening caulk to seal the poly to the walls. i prefer the black poly to the "clear"; much tougher animal. no need for rock to hold it down. crawl spaces should be conditioned, ideally, btw.
Old 05-28-2011, 10:06 PM   #3
Crawlspace
conditioned? Don't understand?
Old 05-29-2011, 02:10 AM   #4
Crawlspace
Heated. Read on buildingscience.com, and or greenbuildingadvisor.com.
Old 05-29-2011, 10:13 PM   #5
In a little over my head
Crawlspace
Does your crawlspace have adequate ventilation?
ratherbefishing is offline   Reply With Quote
getting the most out of a heated crawlspace Gerry Fossum HVAC 2 06-08-2011 08:42 PM
conditioned crawlspace fan albertpinto HVAC 4 12-27-2010 05:46 AM
Crawlspace Moisture - Serious Problem PaoloM General Discussion 11 12-15-2009 02:35 PM
Insulating an unheated crawlspace indignatz Building & Construction 7 10-28-2009 07:29 PM
crawlspace exposed to outside and damp djbauda Building & Construction 5 07-30-2007 08:49 AM
