Crawl Space Wall And Water - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-11-2013, 02:11 PM   #1
Rewards Points: 208
Crawl Space Wall and Water
There’s a concrete corner/crawl space wall in my 1950s house (circled in red in picture) where the ground slopes down. Coincidentally, on the reverse side of the corner is the crawl space, and there’s a little blackness to indicate past water seepage. Is the sloping ground the cause of the water seepage? I have never seen water pool there. Granted, when I bought the house, the nearby gutter downspout (which you can see in picture) was missing.
Uploaded with ImageShack.us
Scully is offline   Reply With Quote
Old 04-11-2013, 02:21 PM   #2
Roofmaster
Rewards Points: 2,210
They make these things called grass rakes.............. Looks like your slab dropped a little. Pretty common with settlement.
Old 04-11-2013, 02:31 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,568
Move the downspout too.
Its just pumping water up against the side of your house.
Old 04-11-2013, 09:57 PM   #4
Rewards Points: 14,312
You have mulch piled up againt the foundation that holds in any moisture and you have water stains on the back side of the wall.
Old 04-12-2013, 03:24 PM   #5
Rewards Points: 208
joe, i see old water stains in that corner in the crawl space. it's not really mulch that's there...just dirt and some leaves. should it be concrete or grass next to the concrete foundation?
Converting Vented Crawl Space to Unvented/Conditioned Achille76 Building & Construction 4 02-19-2013 09:10 PM
Crawl space retaining wall advice needed Ironlight Building & Construction 7 03-09-2012 09:22 AM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 06:38 AM
Whole in Crawl Space Wall? Water Problem? - Picture! donaldp General DIY Discussions 1 03-26-2010 08:52 PM
How to Space Water Heater Flue Vent from Outside Wall? austinbirdman Plumbing 1 03-12-2007 10:28 AM
