Crawl Space Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-28-2015, 04:28 PM   #1
Rewards Points: 664
Crawl space wall
My house has a crawl space where the walls are not entirely supported by a wall of cinder blocks. The beams rest on pillars of stacked cinder blocks every few feet. The only covering of the crawl space is aluminum sheets like you would see in the skirting of a mobile home.
I am worried the pipes may freeze, so I would like to know the best way to insulate the aluminum sheets.
Thank you in advance to all who help.
crescere is offline   Reply With Quote
Old 02-28-2015, 04:32 PM   #2
Rewards Points: 3,130
Knowing your location would help a lot. Adding it to your profile would get you more location-specific advice. What would work in Virginia might not in North Dakota.
Old 02-28-2015, 04:40 PM   #3
Rewards Points: 664
northern Michigan. It gets cold....very cold!
Old 02-28-2015, 04:54 PM   #4
Rewards Points: 3,861
The distance between the pillars is an important piece of missing information.
Off the top of my heady 2" closed cell foam insulation would most likely require the least structure to install. Moisture would not affect it; most rodents don't destroy it.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 02-28-2015, 06:15 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,628
Ayuh,.... What's the history of pipes freezin' at this place,..??
Are ya convertin' a cottage to year-round use,..??
It might be cheaper, 'n easier to install heat tapes, 'n box the Plumbin' in the 2" closed cell foam,.....
Rather than conditionin' the entire crawl space,...
Bondo is online now   Reply With Quote
Old 02-28-2015, 06:58 PM   #6
Rewards Points: 664
I will be installing PEX eventually. There is broken CPVC there now. The house was a foreclosure and is in bad shape.
Old 02-28-2015, 07:00 PM   #7
Rewards Points: 664
Are those styrofoam panels? How do i adhere it to the sides of the house? There is some wood and bare aluminum.
Old 02-28-2015, 08:17 PM   #8
Rewards Points: 664
Okay, I just Googled it. Do I have to pay a company to spray this in the crawl? Is it DIY? How much does it run? This is a rental property, so I can't go too high.
Old 02-28-2015, 10:43 PM   #9
Is there a trailer park anywhere in your area.?
Most trailer parks have several people that level and insulate new trailers coming in for a decent price.? They will more then likely know what needs to be done.
ron45 is offline   Reply With Quote
Old 02-28-2015, 10:55 PM   #10
Rewards Points: 13,994
Is this a rental that your renting, or one you own and your renting?
Big differance.
Old 03-01-2015, 09:51 AM   #11
Nope! you buy it at HD http://www.homedepot.com/p/Owens-Cor...-45W/100320352
Now I am assuming that you are the Landlord. Any money you spend that increases the creature comfort or decreases the utility bills of the tenants helps you reduce the largest expense a Landlord ever faces; turnovers and vacancies. Keeping the wind and cold from reaching the floors of the house does both.
I'm not some activist telling the way things should be. I am a Landlord of 35 years.
Without seeing pictures of the crawl the only thing I can say about installing the insulation is that 2" foam is fairly rigid and anything that holds it in place against the tin under-pining is probably fine. A nail or screw at the top and a small section of rebar driven into the ground with a wire strung between the 2 every 4' may do the job.
Trailer under-pining is installed with a track at the top and bottom. Screwed to the under carriage at the top and secured with 6 or 8" nails to the ground at the bottom. Then something like vinyl soffit ran between the two.
Colbyt
The Following User Says Thank You to Colbyt For This Useful Post:
crescere (03-01-2015)
Old 03-01-2015, 10:24 AM   #12
Rewards Points: 664
Big differance.
I am the landlord getting the house ready to rent to tenants. This is an investment property I own.
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
NickWa's Basement Renovation NickWa Project Showcase 50 07-01-2015 02:16 PM
Odor from Crawl Space G Ollis General DIY Discussions 68 11-02-2013 01:31 AM
Converting Vented Crawl Space to Unvented/Conditioned Achille76 Building & Construction 4 02-19-2013 09:10 PM
Crawl space retaining wall advice needed Ironlight Building & Construction 7 03-09-2012 09:22 AM
