-   -   Crawl Space ventilation with Smart Vent System (http://www.diychatroom.com/f19/crawl-space-ventilation-smart-vent-system-57138/)
srb1194 11-13-2009 09:03 PM
1 Attachment(s)
Hello all, newbie here. I am researching the Smart Vent system to ventilate my crawl space. I live in South Carolina. My current moisture readings underneath are 16%. I am seeing a fair amount of mold spores on the floor joists. The house is about 5 years old and does not have a vapor barrier. I am planning to install the vapor barrier this weekend. I also have a french drain system underneath the house. Moisture comes through at foundation level during excessive rain but leaves the day after the rain. I have attached a sketch for your review. Thanks for any advice you can offer.
Sincerely,
srb1194
Gary in WA 11-13-2009 11:53 PM
The mold is from no ground cover and the joist bottoms exposed to the space's temperature: http://www.buildingscience.com/docum...n-crawlspaces/
http://dirt-crawl-spaces.com/crawlspace-venting.html My location: http://www.energy.wsu.edu/documents/...awl_Spaces.pdf
Be safe, Gary
burgman60 11-14-2009 07:20 PM
Ventilation may not fix your problem
It is widely assumed that moving air through the crawlspace will 'dry' out the area. Not necessarily so. I live in North Carolina have a crawl space, so have some personal experience with the issue. Moving moist humid air is still moist air. It could cause more moisture. First, you should start with the easy stuff, which is to install a vapor barrier and seal the vapor barrier to the foundation walls. Then measure the area after it has stabilized and compare it to your prior reading. You should look at your outside drainage to see if water is carried into your foundation. Landscaping and vegetation near the foundation are also suspects.
srb1194 11-14-2009 07:32 PM
Thanks for the advice. I am doing the moisture barrier at the present time. Check out the info on Smart Vent @ smartvent.net. There system has parameters set so that it will not bring in air unless certain conditions persist. I still feel that this system will benefit my crawl space. Check it out.
srb1194
