Crawl Space Ventilation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-19-2009, 10:49 PM   #1
Rewards Points: 152
Buying a house in the BC Interior, temps range from 40C down to -20C.
Has a dirt floor crawlspace with insulated conc. foundation (rigid white foam) and a blocked off vent to the outside. Ducting runs in crawlspace, has vent installed but is blocked off with cardboard.
During building inspection, looked like there is some plastic sheeting laid down on floor and covered by sand (only noted at entrance to crawlspace).
I've had differing opinions.... some have told me that it's best to have crawlspace vented so you get air passing through. Others have told me that is no good in the summer b/c of the humid air coming in. Another told me to keep crawlspace sealed and keep it warm with ambient heat.
Any other opinions out there??
Thanks!
burnt03 is offline   Reply With Quote
Old 09-20-2009, 06:03 AM   #2
Remodeling Contractor
keeping it sealed with powered vents controlled to allow flow when needed is your best bet. The requirement is to keep the humidity in the crawlspace the same as outside.
Old 09-20-2009, 11:42 AM   #3
You obviously don't want to vent the crawl space to the exterior in cold climates. The link below describes the criteria necessary for unvented crawl spaces.
http://media.iccsafe.org/news/eNews/...equestion.html
mics_54 is offline   Reply With Quote
Old 09-21-2009, 12:22 AM   #4
I'm here in ohio, experienced mason... i usually install Automatic Foundation vents..they automatically open at 70 degrees F and close at 40 degress
heres the link.
let me know if you need any help
http://heating-and-cooling.hardwares...ign=googlebase
Tradesman14 is offline   Reply With Quote
Crawl Space Ventilation with Wiring and Piping Passing Through scubber Building & Construction 1 02-09-2009 08:59 AM
crawl space and moisture Jeremy Hillary Boob, PhD Building & Construction 5 11-27-2008 08:13 PM
crawl space ventilation Richmarti12 General DIY Discussions 2 03-15-2008 06:21 PM
Crawl Space - to vent or not? tomandlu Building & Construction 2 01-15-2008 07:23 PM
Crawl Space In Basement -- Please Help thekid Building & Construction 7 01-04-2008 08:15 PM
