Crawl Space Shared W/ Home & Exterior Porch - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-31-2009, 01:42 PM   #1
Question
Crawl Space Shared w/ Home & Exterior Porch
Are there any long term issues associated with a crawl space extending beyond the perimeter of the interior living spaces, to an exterior tiled porch? The floor joists of the home also extend from the interior living space to the exterior tiled porch. Contractor says that there is plywood above the joists, a cement mortar bed, two layers of RedGard weather proofing, a crack membrane, and then tile applied with thinset and then grouted.
There is one area where a post on the porch was not properly caulked and water penetrated into the subfloor. Contractor claims that when this is sealed, and dried, there should not be any further issues.
We are concerned with the current (but small amount of water damage) as well as longterm issues associated with the crawl space being exposed to outside temperature differentials that could result in moisture. The porch is insulated.
Any thoughts, comments, etc. would sure be appreciated! Thanks!
kristinh is offline   Reply With Quote
Old 05-31-2009, 03:18 PM   #2
You don't mention what state your in. Changes in humidity and temp have a lot to do with the answer your looking for.
Shamus
Shamus is offline   Reply With Quote
Old 05-31-2009, 03:27 PM   #3
Located in Washington State, near Canada.
Gravel crawl space. Plastic vs concrete howard.wheaton Remodeling 1 10-19-2008 12:12 AM
Crawl space dig-out kfowle3 Building & Construction 3 09-10-2008 06:04 PM
Crawl space issue Horseguy General DIY Discussions 2 10-23-2007 06:53 PM
condensation from ac in crawl space Jack Hass HVAC 6 08-23-2007 06:01 PM
