#16 |
crawl space repair
Sure looks like a 100 plus year old house to me.
Thank about it, there was no wiring, plumbing, heating duct to deal with back then. |
#17 |
crawl space repair
There was no access to get into our crawl space, though there is something out there that looks like they were going to put one in. There is access now. In the kitchen. Under the counter.
#18 |
crawl space repair
1925, Joe...it used to be a greenhouse before though.
#19 |
crawl space repair
Oh, Joe, lets hope that for once this time that is not the case!
#20 |
crawl space repair
look at this from another point,,, was the property listed thru a lic real estate broker ? were structural deficiencies noted on the listing ? IF you borrowed $ to finance, what was the licens'd home inspectors' report disclose ? were you represented by counsel ? in most states, nothing said verbally is binding & all information MUST be in writing !
if i were you, i'd call my attorney quickly
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders ! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by itsreallyconc; 02-18-2013 at 06:51 AM. |
#21 |
crawl space repair
If you did get it inspected before buying I'll make a guess, it was an inspector the realitor suggested.
I've never once seen a report from a realitors inspector not pass inspection. I think they show up with a white cane and a seeing eye dog. |
#22 |
crawl space repair
If it were me, I'd rip up the flooring one room at a time and fix/replace the joists with PT lumber, while at the same time digging out deeper for future access, or leave a trap door every so often. And a vapor barrier would go down
| Tags |
crawl space, crawl space repairs, crawl-space ![]() |
| Display Modes | |
| Bad smell in crawl space. | John_W | General Discussion | 30 | 06-07-2013 02:57 PM |
| Vapor barrier issue between crawl space and conditioned basement | gregsenne | Insulation | 3 | 10-12-2012 12:53 AM |
| Air Barrier in crawl space | biglurr54 | Insulation | 6 | 01-15-2012 09:50 AM |
| Cement crawl space ventilation | sheslostcontrol | HVAC | 9 | 05-22-2010 09:32 AM |
| Water in crawl space after it rains and other questions about crawl space. | dupaloop | General Discussion | 1 | 04-13-2010 06:58 AM |
