Crawl Space Pipe Through Foundation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-05-2010, 09:42 AM   #1
Crawl space pipe through foundation
In our crawl space there is a pipe going to the outside furnace/fan that looks to go under the foundation? It looks to be a source of water getting into the crawl space.
Any tips on if this is normal or solutions? Pictures below...
atDev is offline   Reply With Quote
Old 02-05-2010, 04:34 PM   #2
Rewards Points: 5,336
Hopefully it's not a supply pipe to anything. Copper, pvc, electric tape and whatever...
Where does it go? Just follow it and find out what it supplies. When you find out what it supplies you should be able to either figure it out or post back here.
If you have a handy friend, have him take a look.
Ron
Old 02-06-2010, 04:09 PM   #3
I think we need a little more info. Following the pipe in both directions will really help. Is it 2" or 4". Does the crawl space smell like anything? It almost looks like someone retrofitted a drain line?
bmelanco is offline   Reply With Quote
crawl space access question rocky1charle General DIY Discussions 3 01-25-2010 03:10 PM
Foundation crawl space vent size problem Constant Improvement Building & Construction 15 01-15-2009 05:07 PM
Gravel crawl space. Plastic vs concrete howard.wheaton General DIY Discussions 14 12-04-2008 09:39 AM
thoughts on crawl space heating rtoni HVAC 3 09-30-2008 12:47 PM
Crawl space venting... MLO Building & Construction 2 09-23-2006 03:18 PM
