Crawl Space Liner - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-26-2008, 10:13 PM   #1
Electrical Contractor
kbsparky's Avatar
Crawl space Liner
I have been looking into having a crawl space liner installed.
Has anyone seen something like this, or had it done to their house?
Old 11-27-2008, 08:10 AM   #2
Rewards Points: 562
thats a NICE install,,,how did they surround or handle the center supports?? How about pipe intrusions??.. That would cut down on humidity wicking from ground,,,and musty smells from dirt etc.
4just1don is offline   Reply With Quote
Old 11-27-2008, 10:17 AM   #3
kbsparky's Avatar
I expect their website to show off their best work. I really want to see a couple of their actual installs .... references if you will.
I won't fork over several thousand $$$ without being able to have a close inspection of what someone else got for similar ca$h expense.
Old 11-27-2008, 10:23 AM   #4
It sure is nice looking, but I'm sure it was a few bucks. I spent $100 on a box of 6 mil poly in my crawlspace and it cut down on the moisture, dampness, and musty smell a lot. It looks like they just split it down the middle and caulked the sheeting to the pier pours.
jerryh3 is offline   Reply With Quote
Old 11-27-2008, 10:51 AM   #5
Perfect examples are nice. I cannot imagine what the cost of this job was, but since the dirt floor seems perfectly flat and level, there was a lot of work done previous to installation. I have 6 Mil plastic in my crawl. I overlapped seams one foot and sealed with tape (duct tape, of course). I also went one foot up the sidewalls. Makes it a lot nicer when I need to work down there and prevents moisture and musty smell.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Crawl Space Insulation skinny2 Building & Construction 10 12-12-2008 11:36 AM
thoughts on crawl space heating rtoni HVAC 3 09-30-2008 12:47 PM
crawl space confusion shoestring General DIY Discussions 1 07-27-2008 01:06 PM
Crawl Space - to vent or not? tomandlu Building & Construction 2 01-15-2008 07:23 PM
Crawl Space In Basement -- Please Help thekid Building & Construction 7 01-04-2008 08:15 PM
