Crawl Space Into Mini Storage Room - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-01-2011, 06:02 PM   #1
Crawl Space into Mini Storage Room
I just bought a house with a small basement but large crawl. The crawl space has gravel with 4 or 6 mil plastic over it, and is about 4' tall. I was hoping, considering the height, I could almost finish it into a miniature storage room. Shelves will be simple 2x4 and plywood homemade units. My question is with the 'flooring'.
What are my options with building a floor over gravel? It's storage and I'm on a budget, so I don't want to go all out here. No matter what I do, I was going to lay a second layer of 4 mil plastic down to support more weight/movement over it without wearing through it.
Can I nail together a simple 2x4 frame (say 15'x20' OD), with supports across every 24", install T&G plywood over it, and simply lay it there? Would I get all kinds of movement since it's sitting on gravel? Around the perimeter I would build the shelving which would be fastened to both this new 'floor' as well as the existing joists above. Being storage, some movement/shifting/noise really isn't a big deal, I just want to know if you all think it would be solid, and hold together.
Bad idea? Should I just throw stuff in there in tubs like everyone else? It just seems to me like framing a small storage room in there wouldn't be too difficult, and would improve the looks and ease of use.
Thanks!
Mikef5000 is offline   Reply With Quote
Old 03-01-2011, 06:40 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 338
Thanks!
Ayuh,... Is it reasonably level, 'n dry,..?? year-round,..??
Line it with free pallets from dumpsters...
It won't cost ya a dime, 'n you can pack the place Full of totes, or shelfs, or whatever....
Old 03-01-2011, 07:01 PM   #3
Good questions. It looks level. Since it's just gravel, I can adjust it as needed if I find out otherwise.
Their is some moisture visible beneath the plastic, so I'll double up the plastic. But overall the lumber in the area and air is very dry.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Water in crawl space after it rains and other questions about crawl space. dupaloop General DIY Discussions 1 04-13-2010 06:58 AM
Whole in Crawl Space Wall? Water Problem? - Picture! donaldp General DIY Discussions 1 03-26-2010 09:52 PM
Everything rusting badly in the storage room gaza General DIY Discussions 25 06-25-2009 07:00 PM
Crawl Space Shared w/ Home & Exterior Porch kristinh Building & Construction 2 05-31-2009 04:27 PM
