Crawl Space Insulation Questions - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-12-2010, 04:43 PM   #1
Crawl space Insulation questions
Still deciding best way to insulate crawl space.
* I decided that I don't want to remove old deteriorated/torn paper side down insulation-(way to much work and mess).
* I'm thinking of stapling prodex 16" or 48" to joyces under r-13 old deteriorated insulation. (On crawl space it said I would only add r-6, but taped at joints and added to my deterioated insulation I thought it would get down on some cold going through floor. My cost would only about $1100 this way.
* I still would put a thick plastic on floor-(6mill )???
* And mayby a 3/4' silver sheet glued to dirty concrete wall r-5 -- or blue 1' foam with no foil at r-5 glued to wall. Would any or all of this work? My cost total would be around $2000
Thanks tim
Tim Sommers is offline   Reply With Quote
Old 12-12-2010, 11:27 PM   #2
Rewards Points: 1,092
Search "crawlspace" on greenbuildingadvisor.com, then read for a few hours. buildingscience.com, too.
crawl space insulation fvaldez03 HVAC 2 12-04-2010 07:23 AM
Water in crawl space after it rains and other questions about crawl space. dupaloop General DIY Discussions 1 04-13-2010 05:58 AM
Insulating crawl space jenoble99 Building & Construction 10 06-18-2009 12:09 PM
Unvented crawl space insulation ehardman Building & Construction 3 01-13-2009 12:44 PM
Screening the crawl space vents ziggy29 Building & Construction 2 11-29-2006 08:26 PM
