Old 10-28-2009, 03:56 AM   #1
Default crawl space insulation & faced batts
I am wondering if anyone knows if it is ok to use faced-batts of insulation in the crawl space with the facing towards the masonry wall?
Thank you
akdiy is offline   Reply With Quote
Old 10-28-2009, 07:37 AM   #2
In cooler climates, face always goes towards the heated side. But for basement, crawl space walls I would use rigid foam insulation.
Old 10-28-2009, 07:39 AM   #3
no. The vapor retarder (paper facing) must be placed on the warm side. It is still colder outside this wall. However this type of insulation placed on the masonry wall is a very bad idea anyway since moisture travels in both directions. And you really do not need insulation on that wall. Insulate with spray foam along the rim joist filling every bay to get a more effective barrier.
Bob Mariani is online now   Reply With Quote
Old 10-28-2009, 08:50 AM   #4
Default Crawspace
Rather than insulate the walls I would insulate between the floor joists with the vapor barrier against the heated space, leave the walls alone just do the floor. Make sure you tighten up the leaks around the rim joist. And make sure you have adequate cross ventilation just like your attic.
SULTINI is offline   Reply With Quote
More On This Topic
Your sunroom is could be sitting empty most of the time, because it's too hot in the summer and too cold in the winter. Your sunroom can become a place for year-round enjoyment with a few easy steps. Imagine it as a haven--a place to sit and read, eat or... Read More »
Insulation lowers energy costs and cuts down on noise. Most homes have garages with insulation between only the garage and an exterior house wall. Today, more homeowners are choosing to insulate their garages and turn the extra space into a shop or... Read More »
Garage Remodeling Summary
Garage Remodeling Summary by Expert Village
Hi! This is John on behalf of Expert Village in this video clip I will be talking about our garage project. In the beginning of our garage project we had masonry block walls what we did we framed in those walls and we put up insulation. The reason for... Read More »
Hi! This is John on behalf of Expert Village. In this video clip, I will be talking about insulation tips. Now that our wall is fully framed in, we can go ahead and insulate. When buying insulation, there is a couple of things that you want to look for... Read More »
With strategic planning and a little work, you can design and build your house for maximum energy efficiency. An energy efficient house will save you big on utility bills and you'll experience wonderful comfort and health in your home. These tips will... Read More »
Unvented crawl space insulation ehardman Building & Construction 3 01-13-2009 02:44 PM
Crawl Space Insulation skinny2 Building & Construction 10 12-12-2008 01:36 PM
Crawl Space Insulation howard.wheaton Remodeling 4 11-10-2008 09:12 PM
Crawl space insulation howard.wheaton Building & Construction 10 10-21-2008 11:41 PM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Building & Construction 13 08-03-2007 09:48 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
