Old 01-09-2010, 04:01 PM   #1
Post
crawl space insulation
crawl space floor joist should i use unfaced R19 isulation and then plastic or no plastic or something eles?
thevoz is offline   Reply With Quote
Old 01-09-2010, 04:53 PM   #2
Solutions (handyman)
Yes, use plastic. Use a 6 ml (fairly heavy duty), thinner won't hold up.
Mark Harvey is offline   Reply With Quote
Old 01-09-2010, 05:17 PM   #3
if you use batt insulation I have used 6 mill plastic.
A lot of people in our area are moving towards the spray foam insulation. Do not no to much about it but might be something others can comment on and something you may want to use.
canyonbc is offline   Reply With Quote
Old 01-09-2010, 07:00 PM   #4
Moderator
The latest, and the science behind it: http://www.buildingscience.com/docum...n-crawlspaces/
Be safe, Gary
Clothes taking longer to dry?
Old 01-09-2010, 10:41 PM   #5
In my area (Canada) we do not insulate the floor, we insulate and seal the outside walls and make the crawlspace part of the conditioned envelope.
My place was built with vents, but these have been closed for many years.
The above link is very informative!
" The easy answer is to construct a conditioned crawlspace . Construct it like a “mini-basement.”
Old 01-09-2010, 11:22 PM   #6
Xtreme DIY'r
Dirt floor ?
If so you need a vapor barrier over the dirt too
My last house had both....perimeter insulation & floor insulation
Vapor barrier on the dirt
House stayed warmer, crawl space stayed well above freezing
Old 01-10-2010, 12:56 AM   #7
Moderator
Hey, don't blame me, Wildie brought it up........ Location, location, location:
http://www.fpl.fs.fed.us/documnts/te...entilation.pdf
A surprise with ducts in the crawl: (find the surprise!) http://www.advancedenergy.org/buildi...l%20Spaces.pdf
Foam on the walls: If you go conditioned, need air exhaust or inlet/outlet: http://www2.iccsafe.org/cs/committee...E_06_64_07.pdf
Don’t melt the permafrost, and the benefits of a conditioned crawl: http://www.eere.energy.gov/buildings...s/db/35379.pdf
If you go conditioned, take care of the radon: http://energy.cr.usgs.gov/radon/rnus.html
Be safe, Gary
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Unvented crawl space insulation ehardman Building & Construction 3 01-13-2009 01:44 PM
Crawl Space Insulation skinny2 Building & Construction 10 12-12-2008 12:36 PM
Crawl space insulation howard.wheaton Building & Construction 10 10-21-2008 10:41 PM
Crawl Space In Basement -- Please Help thekid Building & Construction 7 01-04-2008 09:15 PM
