Crawl Space And Insulation.. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-19-2013, 08:31 PM   #1
valcarmo72's Avatar
Crawl space and insulation..
I have a crawl space that is approx 15x20. Currently the insulation is exposed in the above beams and is starting to hang down. Looks like cotton candy..for lack of better terms...and I wanted to replace it. I was wondering if there was a way to keep that from happening. The space is not heated of course and the is plenty of ventilation. I was thinking a thick plastic staples up to the beams to hold it there and possibly sealing off the above cavities...and proper textbook way to insulate in between the beams and keeping it from having sagging fibers...thanks in advance for the help.....
valcarmo72 is offline   Reply With Quote
Old 02-19-2013, 10:22 PM   #2
Rewards Points: 150
They make little metal rods(sorry forget actual name) that are wider than bay that u arch up into the bay to hold up the insulation
kaschmid3 is offline   Reply With Quote
Old 02-19-2013, 10:27 PM   #3
valcarmo72's Avatar
Those are already in place. That how the insulation is being held up. The insulation doesn't have waves in it its just the fibers are stringy now and I almost looks like someone was pulling cotton candy. Sorry only way to describe it...I read 3mil plastic sheeting to keep out moisture..maybe the fluctuation in humidity is doing it. What really wanna know is what is the best way to insulate a crawl space using fiberglass for the joists....the rods hold it in place but what else....Thx again
Old 02-20-2013, 01:21 AM   #4
Rewards Points: 1,092
ouch. tear that crap out and replace it with Roxul and rigid foam on the bottoms of the floor joists. tape the edges/ends of the foam and install a 6 or 8 mil visqueen vapor barrier on the floor. search here; lots of threads on insulating crawl spaces.
Old 02-20-2013, 06:04 AM   #5
Rewards Points: 4,750
thinking of tiger teeth ? you could always staple mesh fabric to hold the f/g in place,,, 6mil's popular 'cause apron/vest stores sell it cheap & those stores are EVERYWHERE IF you want a decent vapor barrier that will stand up to crawling/duckwalking/scootching w/o ripping/tearing/shifting, find something substantial,,,we use stego (no financial interest),,, might be overkill but no client has yet complained when we demonstrate its superiority over 6mil stuff
Old 02-20-2013, 07:46 AM   #6
valcarmo72's Avatar
Just saw the Roxul video on their website...defintanelty switch out the fiber for this stuff when its gets warmer. Mold and Mildew resistent. What better can you ask for in a crawl space...thx for the help
Old 02-20-2013, 01:05 PM   #7
stego wrap is 10x what 6 mil visqueen is; very tough stuff. it costs much more than visqueen, and for a reason. i'd use it in a heartbeat.
The Following User Says Thank You to jklingel For This Useful Post:
valcarmo72 (02-20-2013)
Old 02-20-2013, 05:37 PM   #8
just found out we're got a condo crawl space to fix so will do that after the fl trip 6mil's in there now + f/g,,, we were the highest $ but the 2 other bidders said they'd use the 6mil again will grab up some stego & tiger teeth then be outta there in 1 day after all, SOMEONE's gotta pay my greens fees, right ?
Old 02-23-2013, 08:40 PM   #9
Dave Sal's Avatar
Rewards Points: 728
Here is a link about venting crawlspaces. Might make you reconsider your plan.
http://www.buildingscience.com/docum...in-crawlspaces
Dave Sal is online now   Reply With Quote
The Following User Says Thank You to Dave Sal For This Useful Post:
Odor from Crawl Space G Ollis General DIY Discussions 68 11-02-2013 01:31 AM
Converting Vented Crawl Space to Unvented/Conditioned Achille76 Building & Construction 4 02-19-2013 09:10 PM
Crawl space insulation question gregsenne Insulation 11 01-16-2013 03:26 PM
Crawl Space Insulation in NWT Canada too-cold Insulation 3 11-10-2012 02:11 PM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
