Crawl Space Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-09-2012, 03:35 PM   #1
crawl space insulation
Can I improve insulation of floor of 4 seasons room with rigid foam insulation added to bottom of joists? Joists are insulated with fiberglass batts and 6 mil film is on ground covered with gravel. No foundation. 12x16 room supported on piers. Thank you.
cecker is offline   Reply With Quote
Old 08-09-2012, 04:01 PM   #2
Rewards Points: 502
The PIR / PUR rigid boards are far more efficient as insulants than fibreglass batts. Cut the boards to fit tightly between the joists and then drive a few nails in at an angle below in the sides of the joists to stop the boards dropping down.
tony.g is offline   Reply With Quote
Old 08-10-2012, 04:40 PM   #3
Registered User
Rewards Points: 5,482
If no vinyl above, may need to cover f.b. for code: http://www.buildingscience.com/docum...n-crawlspaces/
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
tony.g (08-10-2012)
Old 08-10-2012, 10:30 PM   #4
If you REALLY want to get this right and STOP all moisture problems/mold possibilities and get very HIGH R values, rip out ALL insul and get an insulation spray foam company in a spray foam all joist bays.
The killer on crawl spaces goes like this. Of ANY standard fiberglass insulation gets 5% of moisture in it, then that insul loses 90% of its insul intended values,
21boat is offline   Reply With Quote
Old 08-11-2012, 01:40 AM   #5
Rewards Points: 1,092
If you decide to keep the fg insulation and nail up rigid foam, tape the edges of the foam and/or goo in between sheets. Closed cell spray foam is the best, bus spendy, if the joists are completely covered.
Crawl Space/Foam Insulation DIY cbaur88 Insulation 9 12-08-2011 08:18 AM
Crawl space insulation questions Gates Building & Construction 3 01-26-2011 08:57 AM
crawl space insulation thevoz Building & Construction 6 01-09-2010 11:56 PM
Unvented crawl space insulation ehardman Building & Construction 3 01-13-2009 12:44 PM
Crawl space insulation howard.wheaton Building & Construction 10 10-21-2008 09:41 PM
