Old 06-10-2012, 10:54 PM   #1
I'm a Melvin
Crawl Space Floor Joist Question
The floor joists in my crawl space have the metal brackets that go from one to the other and they look as they form and X. Some of them have not been attached and are just hanging down. I was wondering should I use nails or wood screws to attach these. If I should use nails what kind should I use and the same question for screws.
designwebs is offline   Reply With Quote
Old 06-10-2012, 11:27 PM   #2
Those that I have used or seen are meant to be hammered right in. Don't yours have "claws" on the ends? If not, a couple of 12d nails on each end ought to hold them in place, as it seems to me the nails would be basically in shear.
Old 06-10-2012, 11:31 PM   #3
I'm a Melvin
I'll have to check one the claw thingy on the ends of each. The house was build in 1974 so I'm not sure as I did not pay any attention to them.
Not sure what you mean by nails should be in shear.
Thanks for the fast reply though.
Old 06-10-2012, 11:50 PM   #4
The nails won't be "pulling out" as much as they will be getting "cut off" (sheared) by the braces. When a glacier slides over the ground, it shears off whatever is in its way.
Old 06-11-2012, 12:51 AM   #5
Moderator
I used to nail them with a 10d teco (1-1/2") nail after bending the tab into the wood with a hammer. Be sure to leave a small space between then where they cross or they will squeak from contact with joist flexing.
Gary
Clothes taking longer to dry?
Estimating CRAWL SPACE Excavation/floor support dwtjan Flooring 1 10-05-2009 07:52 AM
Insulating crawl space jenoble99 Building & Construction 10 06-18-2009 01:09 PM
Crawl Space Insulation skinny2 Building & Construction 10 12-12-2008 12:36 PM
crawl space and moisture Jeremy Hillary Boob, PhD Building & Construction 5 11-27-2008 09:13 PM
Insulating split level home crawl space. sithappens Building & Construction 1 02-29-2008 10:47 AM
