Old 07-27-2009, 09:03 PM   #1
Default Crawl Space Encapsulation
Hello,
We would like to completely encapsulate our 900 sq. ft crawl space. Currently 6 mil barrier with five inches of pea gravel that is wet near pit because of defective sump pump.
I've been hearing a great deal about the Clean Advantage System and the EmeShield 60 mil liner with zero perm. Our thoughts are to have a 20 mil liner placed with 3-4 inch concrete. I am concerned with how little I have found about concrete being the preferred method. Is there something wrong with using concrete to encapsulate besides the temporary onslaught of moisture?
Thank You.
Jimmy07 is offline   Reply With Quote
Old 07-27-2009, 10:19 PM   #2
I had 4" of concrete poured last fall and it has been great. I sealed up the vents and with the dehumidifier, it maintains 65-70 degrees with 40% humidity. Since I use for storage, i installed a back up battery pump.
timchi29 is offline   Reply With Quote
Old 07-27-2009, 10:30 PM   #3
New home owner!
Red Squirrel's Avatar
For sure, I really don't see why some crawlspaces are not poured or why there are vents. The crawlspace is still part of the house and should be treated as such, especially on a split level house (half regular basement, half crawlspace). If you don't have any, get weeping tiles installed as well to take care of any water issues. Dampness is one thing but water issues can really be damaging to the foundation's integrity.
Painting the cement with drylock can probably help too. I want to do this with mine. I recently cleaned it all up from junk left over from previous owners, need to do some more vacuuming then prep for paint.
Old 07-27-2009, 11:33 PM   #4
This is encouraging guys, thank you. A reputable builder/engineer that I know in Maine told me to make sure the perimeter edges of crawl are water sealed too.
Since the crawl is only four feet below the living area, we did research on quiet sump pumps. From what I have read the Red Lion fully submersible 1/3 HP 43 GPM cast iron pump is supposedly so quiet, that only water can be heard when discharging. That would be nice..
Old 07-28-2009, 09:56 AM   #5
General Contractor
Crawl spaces usually are not poured to keep costs down. I've explained in other posts why ventilation in non-conditioned crawlspaces is necessary. The reports have also come in now on energy usage and conditioned crawl spaces. It uses more energy (20% to 53% more) to condition the crawl space depending on the insulation methods used. Moisture levels in conditioned crawls are reduced by as much as 20%.
ARI001 is offline   Reply With Quote
Old 07-28-2009, 07:01 PM   #6
makes no difference since 1 has to deal w/crawl spaces as they are & usually not as we would like 'em to be,,, i like cross-ventilation w/humidistat-controll'd fans & fiber-reinforc'd 15mil vapor barrier on the btm,,, about as reasonable as can be done...
insulation between the floor joists, vapor barrier, & tiger teeth'll be a big help, too !
itsreallyconc is offline   Reply With Quote
Old 07-28-2009, 11:48 PM   #7
New home owner!
That sounds like a recipe for mold and lot of moisture. And I thought my crawlspace was bad lol...
Pics here of how mine looks like: http://gal.redsquirrel.me/?level=picture&id=502
Never really thought of insulating the joists though, but given heat rises, it will stay upstairs anyway while the crawlspace stays rather cool. I will use it as the cold isle for my server room.
Old 07-29-2009, 02:17 PM   #8
General Contractor
Actually based on the studies that have been done insulating your crawl space between the joists is more energy efficient then no insulation or insulating the walls only.
Ventilation is necessary in unconditioned crawl spaces and is required by code. Also a 6 mil vapor barrier on the floor area is required by code. Having controlled fans in the crawl will help prevent mold as it adds to the cross ventilation.
More On This Topic
Not only is mold unsightly, it can cause health problems. Mold grows in humid or damp areas of your house and will continue to grow unless removed. After removing the mold, you can prevent it from growing back with a few simple steps. Here are a few tips... Read More »
In this step we will remove the rip vents, install the mider gage, and cut the sidewall boards at a sixty degree angle. To remove the rip vents all I need to do is pull it up off the table saw. To install the mider gage put it in the slot of the table... Read More »
Homemade Odor Eliminators
Homemade Odor Eliminators by Expert Village
Hi there. Today, we're talking all about how to get rid of odors in your home, and I brought forth some great homemade ideas to getting rid of those odors. Now you might already have these things in your cupboard. Sure you could go out and get things... Read More »
How to Use a Duct Blaster
How to Use a Duct Blaster by Expert Village
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are going to do a duct test on this house. This is a duct blaster right here. Okay the reason we are hooking up to the return side of air and maybe I need... Read More »
Hi this is Jon on behalf of Expert Village in this video clip I will show you how to remove your side trim boards. On this side we need to remove our gutter first before we can have access to our trim board. You need to unscrew where you gutter... Read More »
Jacking Up Floor Joists in Tight Crawl Space killerformula Building & Construction 2 06-11-2009 05:23 PM
Crawl Space Insulation skinny2 Building & Construction 10 12-12-2008 01:36 PM
thoughts on crawl space heating rtoni HVAC 3 09-30-2008 02:47 PM
crawl space confusion shoestring General Discussion 1 07-27-2008 03:06 PM
Crawl Space In Basement -- Please Help thekid Building & Construction 7 01-04-2008 10:15 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
