Crawl Space - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-29-2012, 08:35 AM   #1
crawl space
I have a question regarding the crawl space under my home. The crawl space is very large part you can stand. There is a plastiv barrier laid down by the builder. I also have a sprinlker system for the lawn.
I see at one spot near the corner the dirt is low, was this intentional. There has not been a water problems. I assumed the builder or the sprinkler installer did this? Can you please let me know your thoughts
thanks, Janis
janisr is offline   Reply With Quote
Old 04-29-2012, 10:11 AM   #2
AHH, SPANS!!!
Rewards Points: 1,166
the spot that is low could be where the main sewer pipe leaves the crawlspace or where the main plumbing line brings in water to the house through the foundation wall. if the vapor barrier plastic goes over top of the low spot then the low spot was there during the building process and not added afterwards.
hand drive is offline   Reply With Quote
Cement crawl space ventilation sheslostcontrol HVAC 9 05-22-2010 09:32 AM
Insulating crawl space jenoble99 Building & Construction 10 06-18-2009 01:09 PM
insulating crawl space near plate measure thrice Building & Construction 13 01-26-2009 04:11 PM
32 inch high crawl space can a furnace fit tommar HVAC 4 02-20-2008 06:28 AM
Crawl Space In Basement -- Please Help thekid Building & Construction 7 01-04-2008 09:15 PM
