Cracks In Stucco Scratch Coat - Is This Normal? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-30-2009, 11:29 AM   #1
Cracks in stucco scratch coat - is this normal?
Hey all, new here! We are looking at a house to purchase that was built in 2006, and it has the scratch coat for the stucco applied, but not the final coats yet. The house has been with the scratch coat for a few years now, and upon inspection, I noticed tiny hairline cracks in the scratch coat at various places.
I was told that this is because of a poor job applying it and in a few spots if you press on it, it will flex very slightly. There are no large cracks or any spots with missing mortar or anything. I was also told that these cracks could also be from the coat drying to fast (hot weather, not being kept wet enough).
Just wondering if this will be an issue when getting someone to apply the final coats to the house? Will these areas have to be repaired or is some hairline cracking like this normal?
Anyone's help or opinion would be greatly appreciated.
chadurban is offline   Reply With Quote
Old 05-25-2009, 11:13 AM   #2
Anyone?
Old 05-25-2009, 01:41 PM   #3
Old School
Willie T's Avatar
If parts of it are flexing, I think you know you've already answered your own question. It has to be solid.
Willie T
Old 05-25-2009, 02:13 PM   #4
Rewards Points: 5,336
What method of application was done? Traditional or over that foam board?
Ron
Old 05-25-2009, 03:45 PM   #5
Not sure if its traditional or over foam board, is there a way to tell? Don't know to much about stucco, though it is for sure over wire mesh.
There is the very odd spot that if you push on it with your finger, it will flex very slightly. Is this a case where these certain spots will need to be repaired or would the entire job need to be redone?
Old 05-25-2009, 10:55 PM   #6
I've never seen a scratch coat that doesn't have hairline cracks in it.
the carpenter is offline   Reply With Quote
Single Coat Stucco Harpoon Building & Construction 4 04-02-2009 09:46 AM
color streaks on new stucco homeowner in Minnesota Building & Construction 2 08-11-2008 07:07 PM
stucco finish coat efaxsteph Building & Construction 2 03-24-2008 06:23 PM
Is it normal for primer to show thru dark paint on first coat? Autumnknight Painting 5 10-02-2006 06:38 AM
