Old 04-24-2011, 09:43 PM   #1
Cracks in roof rafters
Noticed some cracks in the middle of some of the roof rafters lengthwise:
Should I be worried? Do I need to sister them up?
smguo2001 is offline   Reply With Quote
Old 04-24-2011, 09:45 PM   #2
old guy contractor
tcleve4911's Avatar
That is normal "checking" seen in large timbers.
They are not "cracking".
Just an aesthetic nuisance, not a structural issue.
tcleve4911 is offline   Reply With Quote
Old 04-24-2011, 09:50 PM   #3
Super Moderator
Not a big concern--Those are known as 'heart checks'---The strength of the rafter is not compromised much by that.
If the checks reach the outside of the rafter then it's time to figure a repair.---Mike---
Old 04-24-2011, 09:58 PM   #4
Wow, thank you both! Didn't think I could get replies so quick.
Mike, what do you mean by "outside"? You mean the other side?
Old 04-24-2011, 10:12 PM   #5
Super Moderator
Wood is like a book made of paper---some times the 'pages' have gaps at the edges---no problem.
If the book(wood) is sliced on such a way that the openings are on the cover (face) then the strength of the book is weakened.
This explanation stinks----sorry----Bottom line,you're good. No worries about your house.---Mike----
Old 04-24-2011, 10:17 PM   #6
old guy contractor
tcleve4911's Avatar
.....but he's right.....
Venting a hip roof with exposed rafters Eudaemonic Roofing 1 02-10-2011 09:16 AM
2x4 as roof rafters on an 11x9 shed with ridge beam amakarevic Carpentry 4 01-11-2011 03:54 PM
Tying new roof into old. Clutchcargo Roofing 15 11-07-2009 06:48 PM
garage roof insulation between rafters denverman71 Building & Construction 1 10-21-2009 01:06 PM
Insulating roof rafters in Tenn ? weberus3 Building & Construction 2 10-01-2009 06:36 PM
