Cracks In New Carport Posts - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-04-2013, 04:01 PM   #1
Cracks in new carport posts
Hi all,
I am in the process of replacing my carport posts with 4x4s. After about 1 week I am seeing cracks in the posts. I used pressure treated lumber and I applied wood preservative after I put them up. I also predrilled all screw holes. Is there something else I should be doing to avoid cracking? Is the quality of the lumber just bad. Pictures attached.
Thanks!
Cracks in new carport posts-img_0025.jpg   Cracks in new carport posts-img_0988.jpg
tbick is offline   Reply With Quote
Old 08-04-2013, 04:26 PM   #2
kwikfishron's Avatar
Rewards Points: 1,018
It's normal to see that especially with treated Pine. There's nothing you can or should even try to do to stop it, structurally it's just fine.
If it's the aesthetics that bothers you then wrap the post in WR Cedar, Redwood or PVC trim.
kwikfishron is online now   Reply With Quote
Old 08-04-2013, 04:43 PM   #3
That's good to know. Thanks for the response kwikfishron.
Old 08-04-2013, 06:22 PM   #4
Household Handyman
Rewards Points: 1,408
Welcome to the world of pressure treated southern yellow pine. IF I have stated this once on this forum then I have stated this a lot. From the photos I would definitely state that these are Southern Yellow Pine, by the looks of the grain(s) and knots. Southern Yellow Pine were bread many years ago to grow fast, and grow straight (somewhat). Modern pressure treating processes involve a lot of heat which allows the preservative to enter the wood fibers. But alas-this also stresses the wood's grain and allows the cut lumber to be weakened.
Clarification regarding fence posts flatcoat Landscaping & Lawn Care 2 05-16-2010 04:26 PM
How to replace posts before concrete is poured rosco Building & Construction 31 05-07-2010 02:54 AM
help settling porch posts - a dilemma. wombosi Carpentry 9 10-10-2008 12:01 AM
Cracks in pressure treated posts (4x4s, 6x6s) Deck Building & Construction 8 05-15-2008 10:57 PM
Installation of pergola posts HDelahay Landscaping & Lawn Care 13 10-11-2006 06:46 AM
