Cracks On Internal Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-09-2009, 03:29 PM   #1
bozron
cracks on internal wall
Hi,I live in a terraced house in the UK that was built in the sixties. At that time building regulations were slack as my neighbours central heating flue liner is built in the dividing wall.
I have repaired cracks in the wall many times but as you can imagine as the wall warms up in the winter months and cools off, the cracks appear again.
It is not possible to plasterboard the wall. Can anyone give me ideas on a solution ?
many thanks
Bozron
bozron is offline   Reply With Quote
Old 04-09-2009, 03:33 PM   #2
Structural Engineer
What materials have been used to construct the wall? And do you know the size of your neighbor's flue?
wildcat is offline   Reply With Quote
Old 04-09-2009, 03:48 PM   #3
bozron
re cracks on wall
The flue made from asbestos about 5"
The wall made from breeze block, sand, cement, and plaster.
Thx
Bozron
Old 04-10-2009, 11:47 AM   #4
Structural Engineer
If the block wall doesn't have any control joints they could be added very easily. A "floating" wall could be constructed over the block wall, simply gyp board on furring or channels. The floating wall can built but not attached to black wall, this will allow the block wall to expand/contract without cracking the gypsum board wall. It would probably best to due both the floating wall and adding any needed control joints to the block wall.
Old 04-10-2009, 01:22 PM   #5
Drywall contractor
Rewards Points: 1,070
Do a search for Nu Wall. It is a fabric type of wallcovering for repairing cracked plaster. Don't know if heat will affect it, but I'm sure a call or email to their customer service could answer that question....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
~HELP~ Basement Wall is bowing earthad1 Building & Construction 6 06-05-2008 12:24 PM
Wall to ceiling fw2007 Electrical 4 03-31-2008 06:18 PM
Gluing greenboard to cement wall... tips? AdamB5000 Remodeling 5 03-31-2008 10:11 AM
exposed brick wall Jrr1099 Carpentry 1 03-25-2008 02:45 PM
Low Retaining Wall cibula11 Landscaping & Lawn Care 3 07-29-2007 12:02 AM
