Cracks In Cement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-25-2009, 05:04 PM   #1
Cracks in cement
I have three A/C units on the right side of my home which sit on a large cement slab. The slab connects to the foundation of the house. There is a crack running from top to bottom at the interface. It's not a large crack but there nonetheless.
Also, I have a crack running horizontally in my driveway for a few feet, where the driveway slopes.
Any recommendations on this? I am thinking it would be good to seal these cracks somehow but I don't know what to use.
Any feedback appreciated.
Chris
NightOfDiscovery is offline   Reply With Quote
Old 11-25-2009, 05:16 PM   #2
Civil Engineer
Rewards Points: 4,854
If the driveway is made of asphalt, a crack may be sealed using driveway sealer, cold patch, or hot patch. The concrete crack may be sealed using Thorobond, hydraulic cement, or concrete mix. If it were me, I would not worry about the slab crack, but I would seal the driveway.
Old 11-25-2009, 05:23 PM   #3
Thanks Daniel! I searched for Thorobond and found it for $25:
http://thoroproducts.net/shop/articl...nd-%C2%AE.html
Lowe's or Home Depot do not appear to carry it so I guess I can order it.
Old 11-26-2009, 06:41 AM   #4
Rewards Points: 4,732
even asphalt crks ( note local roads ) &, if you follow those directions, won't make much difference other'n appearance.
conc's different - i suspect the crks due to an incorrect jointing pattern/timing/depth, early loading, or unsubstantial base but my $'s on the 1st,,, you can use dan's but that crk may now be a jnt ( meaning movement ),,, ck & see if there's any spall damage,,, if so, proper crk prep & sealing w/100% silicone's better,,, probably can find directions/sketch on dow/corning's w-site,,, t-bond, hydraulic, or conc mix aren't elastomeric & will fail.
dan's bona fides're civil engineer while mine're sawing/sealing contractor for conc/asphalt hgwys, runways, bdge, roads, etc
Old 11-26-2009, 10:07 AM   #5
DAP Concrete Repair
Thanks for the reply! It looks like DAP Concrete Repair is a good option at $3.98. I can use it to fill the cracks.
http://www.lowes.com/lowes/lkn?actio...021&lpage=none
Old 11-27-2009, 05:01 AM   #6
happy you think so but, sure as hell, i don't,,, who said latex was the right choice ? ? ? then again, i already gave you my pro opinion,,, its YOUR ( ) house
Old 11-27-2009, 09:56 AM   #7
Options
Ok, I should have checked my cabinet. I have a couple options.
100% Silicone:
http://www.lowes.com/lowes/lkn?actio...12A&lpage=none
Conrete Repair (latex):
http://www.quikrete.com/productlines/ConcreteRepair.asp
So you are saying that a silicon product is better to use on a driveway than a product specifically designed for concrete repair?
Chris
Old 11-27-2009, 10:02 AM   #8
Article
I see the following article:
http://www.doityourself.com/stry/usi...ve-on-concrete
"For real precision jobs, the best adhesive on concrete is a 100% silicone caulk."
As long as it sticks well I can see how it would handle a crack better as it is elastomeric.
It is supposed to reach into the 70s tomorrow and so I will try the (clear) silicon.
Old 11-27-2009, 10:13 AM   #9
One more thing... How do I get a tiny bead of silicon? I have a silicon gun but the tip needs to be cut large enough for the silicone to pass through which is at least 1/4".
The bead will be much larger than the crack so I was thinking of using a wooden stir stick to push it along. However, I don't want to have a mess of silicon on either side of the crack.
Thanks.
Old 11-27-2009, 11:41 AM   #10
if you didn't read the section on crk-sealing, http://www.dowcorning.com/content/pu...1015-01.pdfhow do you expect to have it turn out right ? ? ? the crk MUST be ' chas'd ' to provide the proper depth/width sealant ratio,,, typically we saw 'em to 1/2" wide x 3/8" deep then add a bondbreaker tape allowing the silicone to contact & adhere to the crk sides ONLY
http://www.dowcorning.com/content/pu...63-1015-01.pdf - i don't see ' latex ' list'd here NOR do i consider your h/o links worth a ****,,, no pro would,,, here's your mtl - http://www.dowcorning.com/applicatio...EN&DCCSF=269EN,,, what is a ' silicon gun ' ? ? ?
little or nothing worthwhile can be found at an apron store
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 02:25 PM
cement falling into basement from cement porch above. Betsy G Building & Construction 3 10-21-2007 12:53 PM
Cement Utility Sink - Cracks and Leaks amazinlittledevil Plumbing 3 01-25-2007 02:59 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
