Are The Cracks Caused By Foundation/structure Issue? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-13-2011, 01:58 AM   #1
o0o
Are the cracks caused by foundation/structure issue?
Hi,
I saw cracks between (internal) wall and window frame around several windows in a year 2003 house. Are the cracks caused by foundation/structure issue?
Here is one picture:http://picasaweb.google.com/11011074...86745594366130
Thanks for the help,
Eric
o0o is offline   Reply With Quote
Old 12-13-2011, 03:01 AM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Darn it. never mind.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 12-13-2011, 03:07 AM   #3
Disabled wood vet
titanoman's Avatar
Is that a window or a skylight? That mold tells me you have condensation issues or water leaks. Bad install in the first place (drywall "j" channel prevents the separation from looking so bad).
The Following User Says Thank You to titanoman For This Useful Post:
o0o (12-13-2011)
Old 12-13-2011, 03:15 AM   #4
o0o
It is a window, not skylight. how to fix the cracks?
Old 12-13-2011, 03:28 AM   #5
Disabled wood vet
titanoman's Avatar
100% silicone, paint.
Old 12-13-2011, 03:08 PM   #6
Rewards Points: 1,520
Can't paint most silicone caulks; acrylic latex type you can paint. Check the tube before you buy it if it is paintable.
bob22 is offline   Reply With Quote
Stucco cracks and stucco questions FrankL Building & Construction 2 05-22-2011 07:23 AM
Foundation and footing cracks willk53 Building & Construction 5 04-22-2011 09:46 PM
concrete cracks Wiscbldr Building & Construction 15 04-19-2011 07:20 PM
Flood/Drainage Issue On Garage Man Door altc81 Building & Construction 2 04-17-2011 09:19 AM
Cracks in drywall/foundation problems? MusicCity Building & Construction 5 12-26-2010 10:35 PM
