Cracked Plaster From New Roof. How Long Do I Wait To Repair? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-17-2009, 08:27 AM   #1
Cracked plaster from new roof. How long do I wait to repair?
Not sure if this belongs in this forum or under painting, but I thought that I'd try here first.
Anyway, we just had a tile roof installed last month. House is 60 years old stucco over block and the previous roof was shingles. We hired an engineer and added support well beyond his recommendations.
He did state, however, that due to the original builders placing struts midway across the living room ceiling (not above a load bearing wall), we could expect cracking to reoccur there. Sure enough, a visibly patched old hairline crack has reopened.
The surprise, though, is a thin, horizontal crack midway up the wall of non-bearing wall running parallel to the rafters, and perpendicular to the ceiling crack. I wasn't aware of there being any load placed on that particular wall.
I'm not concerned about it as it's probably just settlement.
However, I'm curious about how long to wait before I patch the cracks? I'm inclined to wait until this spring when a snow load should cause additional deformation and more cracking.
Since plaster has almost not give, is there an approach that I should take when patching? Say...cut a 6" wide gap and replace with drywall maybe? Or, is there any elastomeric patch compound that will flex and be more forgiving?
Thanks.
meltdowndave is offline   Reply With Quote
Old 10-17-2009, 09:33 AM   #2
Old School
Willie T's Avatar
Very logical thinking. I, too, will be interested in hearing some informed opinions on this one.
Willie T
Old 10-17-2009, 12:57 PM   #3
Rewards Points: 582
We find that the cracking and bowing of non load bearing upper floor partition walls is common on new build houses when the partitions are built before the roof is tiled. If the crack is hairline normal filling by the decorators should be OK. Plasterers use scrim when covering larger cracks.
stuart45 is offline   Reply With Quote
Old 10-17-2009, 10:17 PM   #4
Thanks for the reassurance.
1'X20' flat roof repair hohadcr Roofing/Siding 2 08-25-2009 11:17 PM
What do you guys think of this roof repair job? darsunt Roofing/Siding 7 08-21-2009 08:43 PM
advice needed on roof repair gdread Roofing/Siding 4 08-13-2009 01:08 PM
Flat repair roof of condo building Stillwerkin Roofing/Siding 7 03-02-2009 06:34 PM
Metal Roof Repair Questions bruce3404@hotmail.com Roofing/Siding 3 09-17-2008 10:00 PM
