Cracked Cement Floor In Garage. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-24-2009, 09:51 AM   #1
Rewards Points: 150
Cracked cement floor in garage.
At my new house, the garage cement floor is cracked through the middle of the garage. One side may have shifted up to 1/4 inch in comparision to the other side of the crack. What is the best way to fix this and that will last other than removing the whole floor and adding new cement?. I was told to grinde the higher side down and patch it. Will this last?
gante is offline   Reply With Quote
Old 02-24-2009, 07:10 PM   #2
there's probably no construction / contraction / expansion jnt down the middle like in mine so i gots a crack, too topping that, we've got expansive soils in atl, ga, [ clay - you should see the bsmt exercise room
i'm grinding the high side & acid-staining but this is our work & i'm not concern'd my work won't last at my age, i don't often buy ripe bananas, either
yesitsconcrete is offline   Reply With Quote
Old 02-24-2009, 07:33 PM   #3
Rewards Points: 1,016
I think 1/4" is not just a stress crack, rather the slab is moving. I would think you should contact a foundation contractor experienced in remedial repairs - if the movement continues, there is no lasting fix for the crack, it will continue to widen.
Old 02-25-2009, 03:12 AM   #4
never heard of a ' stress crack ' in 36yrs,,, yes, it crk'd because of stress - the real question now's not so much why but how to repair it as i understand the post.
simple physics - ALL concrete moves - its a solid & reacts to temp inversely as does liquid to the same force - ie, when conc's HOT, it expands ( hgwys ' blowup ' ),,, when wtr's cold, it expands ( ice ),,, when conc's cold, it contracts - hence, jnts & crks widen.
not sealing exercise room crks,,, my acid-stain'll react differently w/crks than it will w/unblemish'd conc,,, the crk's always-present moisture level creates interesting results w/the mineral salts in my mix but that's the artistic side,,, the other side says sawcut, backer rod, & sealant/epoxy of my choice for the task at hand ( i'd pick polysulfide - it resists hydrostatic pressure AND will ' take ' color ! )
far's experts, 1st guy mentioning hydraulic cement's out the door you won't stop the crk as its already there; you can't hide it unless you pile stuff ' on top of it; you CAN repair/seal it w/this accept'd repair method,,, look for intersecting crks not easily visible to the untrain'd eye - slight crks that ' hold ' moisture when the rest of the floor's dried,,, conc's still undergoing stress ( that word again ) & won't be satisfied til its square horizontally relative to its thickness as a genl rule,,, if crks're already there, live w/it UNLESS: 1, you're positive the cracking'll lead to total destruction; 2, you've got loads of spare $$$; or 3, you're anal w/VERY good credit
' bailout ' is a 4 letter word !
Old 02-25-2009, 05:15 AM   #5
BUILDER / REMODELING CONT
buletbob's Avatar
you said your new house. Is it a one or two car garage?. another theory is that when the foundation was dug the center of the garage was not excavated ( very common ) just the foot print of the foundation was dug. the footings were set and poured and then the wall installed. it sounds as tho when they back filled the inner walls they did not compact it . and what is happening now ,is the soil is settling and the slab is settling with it from the weight of the car, the center of the garage soil was not touched there for will not sink and is acting as a fulcrum. I have seen this on many of homes. The repair method that I have used was a slab jacking company, And to rip the old slab out and pour a new one. and some customers opp out and leave it alone. This is also very common when they install walkways close to the foundation wall. it has a tendency to sink, pitch back to wards the foundation letting water pool along the house. Hope this was of some use to you. Good luck BOB
Old 02-25-2009, 09:32 AM   #6
Rewards Points: 150
Originally Posted by buletbob View Post
you said your new house. Is it a one or two car garage?. another theory is that when the foundation was dug the center of the garage was not excavated ( very common ) just the foot print of the foundation was dug. the footings were set and poured and then the wall installed. it sounds as tho when they back filled the inner walls they did not compact it . Good luck BOB
Very possible. This is a two car detached garage and the crack is somewhat in the middle parallel to the cars parked inside, but I am not sure if this garage had seem much "car" activity since it seems to be that at least the previous owners used it more for storage purposes. Again, we do not know how old that crack is.
I guess there is no "easy" fix to this cosmetic problem and I do not intend to pay for new concrete for now. I will leave it alone for now.
Greg
Old 02-25-2009, 02:08 PM   #7
buletbob's Avatar
AH! So its not a new house! just new to you. But this still might pertain to you. Good Luck. BOB
Old 02-26-2009, 05:54 AM   #8
you gotta be kidding - no easy fix ? ? ?,,, 1st place, unless you repair the crk, damage'll increase; 2nd, if you repair as i post'd, the cost'll be under $100 incl mtl & tool rental; & 3rd, if you're in a freeze/thaw area, damage may be geometrically more than anticipated in #1,,, the crk's there because no contraction jnts were originally installed/cut/sawed.
then again, its YOUR house, not mine ! ! !
Old 02-26-2009, 10:11 AM   #9
Rewards Points: 150
Sorry for the misunderstanding. It is not a new construction. I was build in 1948.
As far as the crack I was looking at it a bit closer and it looks like I may have exaggerated on the verticall displacement of 1/4". Although it is desplaced horizontally to the point that you may be able to insert a pencil in between the crack at some points. I will be looking into patching the crack and see how that goes.
Old 02-26-2009, 11:55 AM   #10
Rewards Points: 1,910
So basically one fairly level crack up to 1/4" wide in a 60 year old concrete garage floor - I'd say you got a pretty decent floor. Use one of the good concrete caulks and seal it up pretty. It will keep water out (eliminates a lot of potential problems). The slab should last another 60 years.
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
Best way to insulating a heated detached cement block garage Joe Nulph Building & Construction 1 03-06-2006 10:30 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
