Cracked Ceiling Joist Near Garage Door Support - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-05-2010, 09:18 PM   #1
cracked ceiling joist near garage door support
I noticed this crack in a ceiling joist near one of the hangars supporting the garage door.
Here's a wider shot, with the cracked section at the far left:
Does this look serious enough to need repair? If so, what's the best way to go about it?
Thanks,
Mike
mikebull is offline   Reply With Quote
Old 07-06-2010, 06:20 PM   #2
firehawkmph's Avatar
Rewards Points: 1,826
Mike,
In reality, it probably won't hurt anything. It cracked from the lagbolt going in. You could screw and glue a rip of plywood on the side showing if you want to help keep it from getting any worse. Looks like conduit running on the other side. If you decide to put the plywood on, replace the two lagbolts holding up the garage door hangs with carriage bolts of the same diameter, drilling through the plywood and 2x . That will help hold the sandwich together and provide good support for the garage door hangs.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Dropped Ceiling attached to metal joist cadmonkey Building & Construction 10 06-18-2010 11:26 AM
Garage Heater Wiring ceiling penetration Question DenverBob Electrical 5 12-28-2009 02:01 PM
Installing a Ceiling in a Garage oldbuffer Building & Construction 8 06-09-2009 10:00 AM
garage ceiling mferguson0414 Carpentry 2 01-13-2009 11:24 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 05:57 PM
