-   -   cracked ceiling joist near garage door support (http://www.diychatroom.com/f19/cracked-ceiling-joist-near-garage-door-support-75478/)
mikebull 07-05-2010 08:18 PM
I noticed this crack in a ceiling joist near one of the hangars supporting the garage door.
http://i889.photobucket.com/albums/a...0/DSC_0262.jpg
Here's a wider shot, with the cracked section at the far left:
http://i889.photobucket.com/albums/a...0/DSC_0266.jpg
Does this look serious enough to need repair? If so, what's the best way to go about it?
Thanks,
Mike
firehawkmph 07-06-2010 05:20 PM
Mike,
In reality, it probably won't hurt anything. It cracked from the lagbolt going in. You could screw and glue a rip of plywood on the side showing if you want to help keep it from getting any worse. Looks like conduit running on the other side. If you decide to put the plywood on, replace the two lagbolts holding up the garage door hangs with carriage bolts of the same diameter, drilling through the plywood and 2x . That will help hold the sandwich together and provide good support for the garage door hangs.
Mike Hawkins:)
