Crack In Glass Mirror - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-02-2006, 06:03 PM   #1
crack in glass mirror
Above my gas fireplace I have a large wall mirror and a crack has started from the corner of a switch hole that was previously cut int the mirror. The crack can't be felt on the surface but you can see it in the mirror about 8 inches long. Is ther anything I can do to prevent the crak from expanding?
rookie50 is offline   Reply With Quote
Old 12-02-2006, 06:28 PM   #2
Rewards Points: 109
crack in mirror
About the only way to stop the crack form expanding would be to drill a hole thru the mirror at the end of the crack.
This is obviously not an ideal solution - but there really is no other way to stop it from spreading.
oberon is offline   Reply With Quote
Old 12-02-2006, 07:24 PM   #3
Its a fine line like 1/32". How do I drill such a small hole?Do they make miniture carbide or diamond drill bits?
Old 12-04-2006, 07:55 PM   #4
Rewards Points: 109
drill
Check with your local glass shop and they may have an extra one that they might sell for a few dollars.
When drilling glass, don't let it get hot...take your time and try not to hurry.
Hanging a Heavy Mirror frapha1 General DIY Discussions 6 01-03-2010 11:21 AM
Custom built legs for very large glass tabletop joeyboy Project Showcase 8 10-06-2008 10:48 PM
Running into difficulties installing bathroom mirror (pics of the nightmare incl.!) joeyboy General DIY Discussions 18 08-10-2007 10:04 AM
How to remove these 'pads'? Solvents? Mechanically? (Pads on mirror!) joeyboy General DIY Discussions 11 08-04-2007 06:01 PM
Sliding Door Glass Replacment ryans Building & Construction 2 04-18-2007 08:49 PM
