-   -   crack in glass mirror (http://www.diychatroom.com/f19/crack-glass-mirror-5172/)
rookie50 12-02-2006 07:03 PM
Above my gas fireplace I have a large wall mirror and a crack has started from the corner of a switch hole that was previously cut int the mirror. The crack can't be felt on the surface but you can see it in the mirror about 8 inches long. Is ther anything I can do to prevent the crak from expanding?
oberon 12-02-2006 07:28 PM
crack in mirror
About the only way to stop the crack form expanding would be to drill a hole thru the mirror at the end of the crack.
This is obviously not an ideal solution - but there really is no other way to stop it from spreading.
rookie50 12-02-2006 08:24 PM
Its a fine line like 1/32". How do I drill such a small hole?Do they make miniture carbide or diamond drill bits?
oberon 12-04-2006 08:55 PM
drill
Check with your local glass shop and they may have an extra one that they might sell for a few dollars.
When drilling glass, don't let it get hot...take your time and try not to hurry.
