Crack In Foundation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-14-2012, 12:39 PM   #1
Crack in foundation
I purchased a home about ~8 months ago and had noticed a little bit of water on an unfinished basement wall (underneath the stairs). Yesterday while caulking a door, I noticed a fairly large crack in the homes foundation. Image: http://imgur.com/zBfCU. Is this something I should try to fix myself? I guess my big worry is how far up and down it stretches. I'm planning to dig a little bit to see how far down goes, but I have no way of know how far up.
I found this video: http://www.5min.com/Video/How-to-Rep...Crack-80714453 that uses a concrete filler for fixing a crack. Would I be ok doing the same?
zenox is offline   Reply With Quote
Old 06-14-2012, 01:25 PM   #2
Stay-at-home GC
He's pulling the caulk gun the wrong way. It drags the bead out of the crack. He should be pushing into the nozzle.
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 06-14-2012, 01:26 PM   #3
Trucon01's Avatar
Rewards Points: 510
I can't bring up your photo... In the mean time, view page 5 of my basement project. I had a crack in my foundation and i patched it with hydraulic cement and blue max... Time will tell if it works for me.
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 06-14-2012, 01:29 PM   #4
joed's Avatar
Rewards Points: 13,736
He didn't squeeze anywhere near enough caulk into the crack. He just barely put some on the surface and then he left gaps.
For your crack I think I would dig down as far as you can from the outside. Clean the wall and then install a flexible membrane type material over the area to seal the crack. There are many different brands that all have different installation procedures. It just needs to be flexible so it doesn't crack open again if the wall moves a bit.
Old 06-14-2012, 01:37 PM   #5
Awesome, thanks for the replies! I think I'll go ahead and tackle this myself.
Old 06-14-2012, 02:43 PM   #6
Rewards Points: 3,826
Hydraulic cement will fix it in a jiffy.
Canarywood1 is online now   Reply With Quote
Tags
crack in foundation , leak in basement
Foundation crack on old milk barn. How to fix?? esblair Concrete, Stone & Masonry 2 02-20-2012 12:34 PM
horizontal crack in foundation jpenns Building & Construction 11 07-28-2011 01:46 PM
Crack in foundation? cbzdel Building & Construction 6 09-02-2010 09:12 AM
Long crack in foundation Hasso Weiland Building & Construction 5 07-01-2010 10:16 AM
foundation crack -- uncovering footing AFTER interior drain tile put in? downers Building & Construction 6 05-18-2009 12:07 PM
