Crack In Brick Siding Safe/serious? (pic) - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-13-2010, 09:04 AM   #1
Crack in brick siding safe/serious? (pic)
Have a home inspection on this one on Friday. Do I need to call in a structural engineer or masonry expert? House built in 1990 and is completely brick wrap.
This area looks like it has already been tuck-pointed once to me....poorly.
Is the crack through the brick partcicularly bad?
Thanks -- nb here -- IG
Crack in brick siding safe/serious? (pic)-img_0859.jpg
indianagraham is offline   Reply With Quote
Old 02-13-2010, 09:16 AM   #2
something settled improperly or the lintel down there fatigued and dropped a bit.
Now is that something to be concerned about? I am not sure but I would definitely have a mason come take a look and if he suggests and engineer then go from there.
wnabcptrNH is offline   Reply With Quote
Old 02-13-2010, 10:59 AM   #3
joed's Avatar
Rewards Points: 11,560
Looks like it has been repaired once. Some of those bricks look new. Something in the foundation is shifting or there is not proper support above that door. How serious would need an on site inspection
Old 02-13-2010, 11:03 AM   #4
can you get a pic from further out to show more, they may have just stacked brick on pediment
The older I get the better I was
Old 02-13-2010, 02:07 PM   #5
Rewards Points: 5,336
Are you in a freeze zone? Any evidence of water under the entrance? Or under the window inside?
Ron
Old 02-13-2010, 03:23 PM   #6
Contractor
Brickie's Avatar
Rewards Points: 79
I see this type of stuff all the time. I would call in a mason & have them fix it properly. Whoever did the tuck pointing on it didn't know what they were doing. You state that you are having "a home inspection on this one on Friday." Are you looking to buy it or sell it?
Northwest Indiana Masonry
http://www.nwindianamasonry.com
Brickie is offline   Reply With Quote
Old 02-13-2010, 05:36 PM   #7
replies
Thanks for the info. Here is a new pic (from farther out per request) and answers:
1. We are looking to buy (inspection is this Fri)
2. We live in Indianapolis, IN (freeze zone)
3. No evidence of mosture inside window or inside at all that is obvious
What do you think?
Crack in brick siding safe/serious? (pic)-img_0861.jpg
Old 02-13-2010, 07:28 PM   #8
I'm thinkin no lintel for brick support and the window above is the natural weak point to the pediment so the stress follows that line. The fact that it is breaking bricks in half is not good. Not sure how or if the brick has a ledger to sit on but that first course of brick after the soldier course up to the window needs to probably come out. I would suggest a lintel on the soldier course to 8" past the vertical outside line of the pediment then relay to the window. If you take a piece of mortar to a brick supplier they can color match the mortar, they may be able to match brick so you dont have to reuse. hope this helps
Old 02-13-2010, 07:30 PM   #9
please make sure flashing is sealed well as water intrusion is good possibility even tho not seen inside
Old 02-14-2010, 11:39 AM   #10
Handy
Make sure the inspector addresses this in his report. That way you can either get further concessions from the seller or back out. If this were a 100-year-old house, I wouldn't be as concerned; but only 20 years? You are right to be concerned.
Hemingway is offline   Reply With Quote
Old 02-14-2010, 01:03 PM   #11
Chicago, IL
Michael Thomas's Avatar
Depending on what's below the window, it's possible that there should be a full arch lintel: back there to support the masonry above.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 02-14-2010, 01:10 PM   #12
Rewards Points: 582
It could be the brickwork is just corbelled across, and this is the problem. It looks an ongoing defect.
stuart45 is offline   Reply With Quote
Old 02-14-2010, 03:37 PM   #13
What does this mean?
Old 02-14-2010, 04:24 PM   #14
Rewards Points: 582
Corbelling is when the bricks are stepped over as shown in the photo.
A lintel as shown Michael's should have been used, but this method may have been.
Crack in brick siding safe/serious? (pic)-pd2597953.jpg
Old 02-14-2010, 04:38 PM   #15
thanks! What would a new lintel and new brickwork cost appx? I imagine a lot more than tuck-pointing... I just want a ballpark so I know how hard I have to push to get this into the purchase.
? RE:Replacing exterior brick with LP lap siding on a poured concrete foundation Greg D Building & Construction 0 11-26-2009 08:49 PM
Replacing Brick with Wood siding HLB Carpentry 1 06-11-2009 11:17 AM
Siding and Brick veeneer wall? sandyman720 Building & Construction 9 08-13-2007 05:02 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
