Crack In Basement Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-17-2010, 10:20 PM   #1
crack in basement wall
just had a addition put on my house .where my new basement connects to the old part. i get water from the crack where the 2 walls meet. what is the best thing to use to seal the crack water tight. thank for any input. Jim
dizzy46 is offline   Reply With Quote
Old 05-18-2010, 05:53 AM   #2
Sounds like a poor mating job, but how big is the crack?? For cracks up to about 1/2", urethane caulk, and not the urethane foam in spray cans.
Old 05-18-2010, 11:42 AM   #3
Rewards Points: 156
I have heard very good things about drylock and drylock paint, but have never used myself. Maybe it would be a good idea to either tuck morter into the joint or use some heavy duty caulking and go over the area with a couple coats of drylock paint. Just a suggestion
Branden is offline   Reply With Quote
Old 05-18-2010, 01:06 PM   #4
Rewards Points: 4,790
impo, drylock sucks but so does ANYTHING else done from the inside,,, either stop it outside OR inject hydrophyllic polyurethane grout into the crk thru epoxy injection packers,,, its a little late to remind the constructor to use waterstop in that location.
ps - hydraulic's better but will still fail,,, remember, wtr runs downhill,,, if it can't enter thru the crk you see, what happens to the wtr ? be easy on branden - he's a newbie ;-)
Best way to cover over brick wall in basement? tigereye Remodeling 4 04-14-2009 10:24 PM
Load bearing wall in basement Ezekiel Building & Construction 3 11-12-2008 09:23 PM
~HELP~ Basement Wall is bowing earthad1 Building & Construction 6 06-05-2008 12:24 PM
Basement leaks in brick wall Nick General DIY Discussions 8 07-18-2006 04:29 PM
Basement wall Problem dazusa Building & Construction 2 01-20-2005 09:16 AM
