Old 07-03-2009, 07:41 PM   #1
kalefarmer's Avatar
Question Covert pole barn into house
I recently bought some land with a really nice 25x55 "wood pole barn" (I think thats the term). It is only a couple of years old, solid, with a new metal roof. I want to convert it into a house but I am concerned about the foundation. It was built with 4x4 posts set directly into the ground. I drilled down beside a couple of the posts with a 3 foot 1/2" drill bit just to see if there was any concrete around the posts below the surface. I didn't hit anything so it would seem the posts are just backfilled with dirt. I know this type of post setting can be common with pole barns but if I convert it into a house...
Could this be a problem? I was thinking of pouring a slab too.
kalefarmer is offline   Reply With Quote
Old 07-03-2009, 08:53 PM   #2
nap
You talking to me?
nap's Avatar
you need to speak with the building department in your area as to the codes involved. a pole building is not acceptable, in many areas as a residential structure.
Old 07-03-2009, 10:41 PM   #3
kalefarmer's Avatar
There are no building codes where I live.
Old 07-03-2009, 10:50 PM   #4
Extreme DIY Homeowner
Scuba_Dave's Avatar
Building codes exist thru-out the US
You may not have permits & inspections where you are
But the codes still exist
A building code is a set of rules that specify the minimum acceptable level of safety for constructed objects such as buildings
The major model building code used in the United States is developed by the International Code Council (ICC), the International Building Code (IBC).
Old 07-03-2009, 10:58 PM   #5
Scuba_Dave's Avatar
Where are you located?
The posts in dirt would be a real problem if you are in a frost area
How tall is the building?
I've seen lots of barns converted around here
Old 07-04-2009, 12:11 AM   #6
kalefarmer's Avatar
I live in Kentucky so there is some frost here. The barn has been around a few years with no noticeable settling so far. It has a flat roof that is 15 feet tall at the front and slopes down to about 11 feet at the rear. If this post/foundation is a problem can it be fixed?
Old 07-04-2009, 12:28 AM   #7
New home owner!
Red Squirrel's Avatar
I'd get it jacked up and have a basement done. This aint cheap though, but if you bought the property without an actual house I'm guessing you had intent to build anyway.
Old 07-04-2009, 08:56 AM   #8
kalefarmer's Avatar
I was planning to build but lack of funds got me thinking I could save a bundle of time and money buy using the barn.
What is the worst that can happen? Post rotting? Settling? Is there a low cost solution to make this work?
I read that the post usually rot at the surface. Maybe I could dig down a foot or two and wrap them or coat them before I pour the slab???
Also if I covert this into a house and set up a proper drainage system around the house wouldn't that cut down on the moisture around the post?
Tags
barn, convert, house
More On This Topic
Hi, I'm Mark Sullivan for Expert Village. Today we will show you how to build a privacy fence around your yard. After you have dugged your post holes you would set the 4x4 post into the hole. Then you would see if they are once you get it level. So here... Read More »
Now we are going to show you how you can attach a new picket fence to a pre-existing picket fence. Now what we have done here is we have taken this pressure treated 2x4 and we have simply nailed it to a pre-existing 2x4 foot pressure treated frame. Now... Read More »
In the wake of environmental and energy crises, alternative building methods have become more popular. Some of these methods are rooted in traditional building styles. One such method is known as Post/Shoring/Polyethylene, or PSP. The PSP building method... Read More »
This is my pressure treated 2x4 used for the framing of your picket fence. Now on this picket fence the frame, the bottom, and the top are pressure treated 2x4's. Now since this is a 24 foot long fence we will need 6 - 8 foot 2x4's. Now when you measure... Read More »
Pole Barn Plans snateman Carpentry 1 06-17-2009 08:09 AM
Moving a House 70 miles- Practical? GOTHICrevivalRULES Building & Construction 19 11-27-2008 10:58 PM
Pole Barn johns Building & Construction 3 01-27-2008 03:56 PM
Changing Alligator Barn into house Rosie Carpentry 6 01-06-2008 05:26 PM
Pole Barn Girts, etc... DonAK Carpentry 1 08-16-2007 11:06 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
