Covering Up Asbestos Duct Tape - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-05-2012, 12:42 PM   #1
covering up asbestos duct tape
we think the best way to handle this is to tape over the asbestos duct tape with a wide foil tape making every effort to not disturb the asbestos duct tape. . can this be done safely?
CraigR is offline   Reply With Quote
Old 04-05-2012, 12:59 PM   #2
Ravenworks's Avatar
Yes but painting it to seal would be easier and cheaper
Ravenworks is offline   Reply With Quote
Old 04-05-2012, 01:12 PM   #3
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
I've got a couple of return ducts that have asbestos on them. I've always just let them sit there. You can paint over it? Spray?
CoconutPete is offline   Reply With Quote
Old 04-05-2012, 05:51 PM   #4
joed's Avatar
Rewards Points: 12,862
Depending on where you live only a licensed asbestos abatement contractor can touch this in any form.
Old 04-05-2012, 06:04 PM   #5
MarginallyQualified
Rewards Points: 2,464
Use duct mastic with 2" throw-away brushes.
Use it on ALL your hvac joints.
Old 04-05-2012, 06:06 PM   #6
Ravenworks's Avatar
Seriously?
A homeowner can(not) encapsolate it?
Old 04-05-2012, 07:43 PM   #7
joed's Avatar
It depends on where you live. I believe some areas are much more strict than others.
Old 04-06-2012, 01:52 PM   #8
Drywall contractor
Rewards Points: 1,070
I would think a homeowner can "encapsulate" as TarheelTerp suggested (and that's the product I'd use). Abatement may be a different story. I can only speak for the lead paint requirements. EPA requires me to be a "certified renovator" to test and work on pre-1978 homes and take necessary precautions or face stiff penalties. A homeowner doing his own work is not required to even test for lead if he chooses not to...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 04-06-2012, 03:09 PM   #9
Rewards Points: 1,580
NOT duct tape. It will dry out in time. The mastic is likely the best method available to a DIYer outside of a check book to have it done by a pro.
bob22 is offline   Reply With Quote
Asbestos on Duct? mk00 HVAC 3 04-04-2012 01:15 AM
Asbestos on ducts and duct supply boots DanGauer HVAC 4 08-31-2010 07:09 AM
Regular duct tape for bathroom exhaust? dtran HVAC 1 10-27-2009 03:26 AM
Encapsulating old asbestos vinyl tile Familypro40 Flooring 17 03-22-2009 03:20 PM
Can I use duct tape? Dusty HVAC 2 09-27-2006 08:28 PM
