Covering Recessed Lighting With Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-04-2008, 05:57 PM   #1
Covering recessed lighting with insulation
For insulating my attic, I have heard that I should leave a 3" no insulation zone around lighting fixtures like recessed lighting cans.
I am now using those cool and energy efficient flourescent tubes instead of incandescent bulbs, so, it makes a lot less heat. Is it now safe to cover the fixture with insulation batting?
Thank you.
bob with 4 dormers is offline   Reply With Quote
Old 12-04-2008, 06:30 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 488
Only if the recessed lights are rated for in contact with insulation. If the cans are not rated for in contact, the you have to maintain the clearance.
jbfan is online now   Reply With Quote
Old 12-04-2008, 07:26 PM   #3
thank you!
I apparently did not read far enough on the fixture. It is an IC.
Does this mean I can seal it for air as well?
Thank you
Tags
insulation
insulation around recessed lighting wiggs Electrical 8 03-17-2011 01:28 PM
Recessed Lighting - Quality Question. 811Gibbon Electrical 8 01-24-2009 09:47 PM
Recessed Lighting vs Electrical/Mechanical/Fire Code 909 Electrical 3 05-21-2008 01:11 PM
Recessed Lighting under hot/cold supplies?? KC10KEVIN Electrical 1 05-08-2008 10:21 PM
recessed lighting in basement DIY4EVER Electrical 6 06-29-2007 02:52 PM
