#1 |
Covering pipe that runs along floor and wall...
So I covered the pipe that runs across the wall with help from someone in this thread...
Covering a pipe that runs along wall? Now I need to cover another. Any suggestions?
#2 |
Is this house on a slab?
Also please go back and add your location to your profile. Just hit the area where your name is in the top right to edit. |
#3 |
I'm converting a car port on a slab into living space...
#4 |
What's behind that stone wall?
Do you even need that pipe there any more if your converting it? |
#5 |
House on other side of the wall. That pipe feeds the outdoor kitchen that was added as some later date...
I guess I could box the pipe in and make it look like trim but I don't know how I would attach it.., |
#6 |
Why not just get rid of it?
#7 |
It supplies water to the outdoor kitchen...
#8 |
To turn a carport into living space, the slab is usually required to have a footer. Does yours? In my experience, most do not. Are you getting permits for this job?
#9 |
yeah its has a footer...the car port was partial converted when we bought the property...
now if i could get some answers instead of a bunch of questions it would be sweet! |
#10 |
There is no pretty magic way to cover this up that's why were asking questions to see if there's a better way to run it.
If there's a crawl space behind that stone wall why not just run the pipe through the wall and get rid of all that exposed piping? |
#11 |
The other side of stone the dining room. The pipe must be there and can't be moved. Can't never could so ill figure something out...I was just hoping for a little help
#12 |
Btw...The spigot will be concealed by a cabinet/desk. I only need to do something about the pipe THST runs along floor...
#13 |
AHH, SPANS!!!
I'd rip two boards, one about 2 1/2" wide and the other 1 3/4" wide and make an L out of them, paint them brown and set the L on the floor with the 1 3/4" on the vertical across the entire room covering the pipe were it sits and just being on the wall for the rest of the room. you can scribe this L to the rock wall and cut out all of the rock scribes in the backside of the L to make it fit to the rock wall. that is concrete so the L would be best to be tough wood, treated or pvc etc... so it does not soak up moisture... use glue when installing and place something heavy a top the L to hold it in place while the glue sets
#14 |
Roofmaster
How about rerouting it over the top in the attic space?
" A lot of men build things, and a lot of things fall down " |
#15 |
"You can do anything"-Mom
if the spigot is going to be concealed by a cabinet / desk just box out the pipe to look like another leg support then box out another one so that it looks symmetric.
| Display Modes | |
