Covering A Ceiling With 1/4" Drywall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-28-2012, 11:09 AM   #1
Exclamation
Covering a ceiling with 1/4" drywall
I have a home built in 1974. The attic was sorely under insulated so was sprayed with loose fill cellulose up to 10-14". This caused a sag in the master bedroom ceiling. Which is drywall. The sag was removed by putting 2.5" screws into the joists every 10-12" or so. The sag is gone but wrinkles from the sag remain.
I furred the ceiling with 1x3" to the joists using 3" wood screws into the joists. Every 20-24". I would now like to recover the ceiling but want to avoid putting as much weight on the joists as possible. They are 2x4 joists (no constant on-center width, found out after I bought the house) they range from 16 out to 20.5" on center. I have attic access prior to the insulation blow in there is no water damage, mold issues, etc.
Can I use 1/4" drywall over screwed to the furring with 2" drywall screws and not have the 1/4" sag? Or do I have to use 1/2" - 5/8".
chaostactics is offline   Reply With Quote
Old 06-28-2012, 11:13 AM   #2
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
From what I can recall, you can't use 1/4" there - it's going to sag. 1/2" is good for ceilings on 16" spacing without sag. I think with your 20-24" spacing, you will need to use 5/8" or 1/2" ceiling board.
hyunelan2 is offline   Reply With Quote
Old 06-28-2012, 11:20 AM   #3
Rewards Points: 2,212
In most if not all places 1/4" costs more than 1/2" ceiling board, go with the 1/2" CB or 5/8. Will give you strength and cost less.
You can get metal extensions for your ceiling boxes if needed.
Is there a reason you were thinking 1/4"?
mae-ling is offline   Reply With Quote
Old 06-28-2012, 11:25 AM   #4
No other reason except weight cutting.
THANKS GUYS FOR THE QUICK RESPONSES
Old 06-28-2012, 11:28 AM   #5
Remember you will need screws long enough to go through your existing ceiling as well.
I always get 1.5" + whatever thickness of ceiling you have now.
Old 06-28-2012, 11:36 AM   #6
If I'm going into the 1x3 furring why do I need to penetrate the existing ceiling as well? (Not arguing just asking)
If I were to penetrate the dry wall I'm hanging, the furring, and the current drywall ceiling I'd need nearly 3" screws.
Old 06-28-2012, 11:44 AM   #7
Sorry my bad. overlooked that part.
Yeah 1.5" would be fine.
Old 06-28-2012, 10:56 PM   #8
Registered User
Rewards Points: 526
I'd use lightweight drywall, 1/2"- spans same as 5/8 because of fiberglass strands but is 30% lighter than regular. http://www.theweighthasbeenlifted.com/
Use lightweight compound (also 30% lighter), same adhesion as all-purpose regular mud;http://www.usg.com/rc/installation-a...s-en-J1795.pdf
A few tips for your install: http://www.finehomebuilding.com/PDF/Free/021174058.pdf
The answers to a multitude of future questions (screw length included): http://www.lafargenorthamerica.com/G...%20English.pdf
Gary
Old 06-28-2012, 11:27 PM   #9
You have a home that was built in 1974 that has 2x4 ceiling joist??? How far do these joist span? Sounds like that is your whole problem to me.. Is it a truss roof?
CopperClad is offline   Reply With Quote
Old 06-29-2012, 07:23 AM   #10
Yes it it a truss roof, rest of the house seems to be built to withstand a bomb blast (has survived an earth quake or 3). The roof not so much un even on center spacing, 2 x 4 construction.
Old 06-29-2012, 10:10 AM   #11
This seems like the best choice for the job
Sheetrock Ultralight
http://www.homedepot.com/Building-Ma...kuId=202938937
Says stiff, for upto 24" on center, and its light weight. It got bad reviews for wall use, but otherwise positive reviews.
Old 06-29-2012, 07:27 PM   #12
Rewards Points: 1,482
Had you run the 1x3 perpendicular to the joists, and spaced them at 12", or 16" OC, you could have use 1/4" rock.
If you did run them perpendicular, just add some additional ones to fill in.
Personally, I would still use at least 3/8" rock, as the 1/4" rock doesn't usually have a good tapered edge to work with.
ktkelly is offline   Reply With Quote
Ceiling Drywall question Mstrenke Drywall & Plaster 9 05-18-2012 11:09 PM
Removing Ceiling Drywall maenos Drywall & Plaster 14 03-08-2011 09:48 AM
Installing Drywall Ceiling daytrepper Drywall & Plaster 10 02-10-2011 12:52 AM
finishing a drywall ceiling mmhendrie Building & Construction 12 03-17-2009 09:11 AM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 03:00 PM
