Covering A Basement Wall That Is Painted - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-02-2010, 03:41 PM   #1
Jordan83
Send a message via AIM to jordan83 Send a message via MSN to jordan83
Covering a Basement Wall That is painted
I am finishing my basement and the previous owner had painted 3/4 of the basement with paint on the walls.
I am trying to find out if I need to strip the paint before studding out my walls or is it ok to build right over it ?
jordan83 is offline   Reply With Quote
Old 11-02-2010, 05:13 PM   #2
Rewards Points: 4,656
depends,,, what color did he use ? ? ? not to worry - stud away
just pay attn to moisture tests, insulation, air space offset, etc
Old 11-02-2010, 09:13 PM   #3
Registered User
Rewards Points: 5,518
Where are you located?
Gary
Gary in WA is online now   Reply With Quote
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 4 04-04-2017 07:38 PM
crumbly interior basement wall el_jefe11 Building & Construction 5 06-24-2011 11:17 AM
Attaching a worksurface directly to studs in of a basement wall BasementVirgin Building & Construction 3 10-06-2010 12:04 PM
Need unbiased help on finishing basement - Dry wall or panel system? mmr1234 Building & Construction 6 08-29-2009 10:30 AM
Basement leaks in brick wall Nick General DIY Discussions 8 07-18-2006 04:29 PM
