Covered Patio Rafters - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-24-2013, 12:00 AM   #1
Rewards Points: 892
Covered patio rafters
Simple question.
What size rafters for a 17' span / 2' on center covered patio? I did a 10 foot span and used 268, but would a 17' require something bigger? 2x8?
No gable - flat porch.
thanks
Daugela is offline   Reply With Quote
Old 11-24-2013, 06:29 AM   #2
Rewards Points: 502
And the rest.
tony.g is offline   Reply With Quote
Old 11-24-2013, 07:04 AM   #3
PoleCat's Avatar
Rewards Points: 1,652
Snow loads are no issue. I would use 2X8 min. just so I could walk up there though.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 11-24-2013, 07:18 AM   #4
Rewards Points: 14,010
Where do you plan on finding 17' long lumber?
A standard would be 16' long.
Old 11-24-2013, 07:24 AM   #5
PoleCat's Avatar
Menard's has 18'. Bet they aren't that far west though.
Old 11-24-2013, 09:27 AM   #6
Rewards Points: 892
Yeah no snow loads in Phx. We did get record rain though this weekend. It's been raining for 3 days straight here.
Anyways, I could theoretically change my plans from 17 to 16 but would rather not. It's not a deal breaker. I haven't looked at any span charts yet.
Could the 2x8 be used if it's 16" - 0? That way I wouldn't be in the "minimum" area. Or I guess 2x10 at 2' - 0.
Old 11-24-2013, 10:16 AM   #7
kwikfishron's Avatar
Rewards Points: 814
Every lumber yard I've ever dealt with stocked 18 and 20' 2x's. It's only in the box stores I've seen length limited to 16'.
kwikfishron is offline   Reply With Quote
Old 11-24-2013, 11:16 AM   #8
GBrackins's Avatar
Rewards Points: 2,108
it depends on your code requirement for live load and the grade and species of wood selected. these span tables are from the 2009 International Residential Code:
http://publicecodes.cyberregs.com/ic...9_8_sec002.htm
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 11-24-2013, 08:07 PM   #9
Rewards Points: 892
Im trying to figure these tables out and am having a hard time. I'm looking at Douglas Fir, NO snow load, live load 100p/sft. I can't get a span further than 9 feet for 2x10s. Makes no sense.
Surely I'm doing something wrong…
Old 11-25-2013, 04:49 AM   #10
Rewards Points: 502
live load 100p/sft.
Your live load won't be anywhere approaching 100 lbs/sq ft, unless you are using the roof to store your collection of vintage cars.
I wouldn't know your code requirements, but it will be much lower, if only for occasional maintainance, say 10-20 lbs/sq ft? Your dead load (ie the weight of the structure) will be quite low - maybe 5-10 lbs/sq ft.
2x10@2ft centres would be fine.
The Following User Says Thank You to tony.g For This Useful Post:
Daugela (11-25-2013)
Old 11-25-2013, 07:52 AM   #11
Rewards Points: 892
A guy on here said 100lbs/sqft. His reasoning was so a person could walk on it for maint, etc…Made sense at the time. Now that you're mentioning it, that is way overboard.
Thanks for the input.
Old 11-25-2013, 12:38 PM   #12
GBrackins's Avatar
live load for living space is typically 40 psf, bedrooms are typically 30 psf. a call to your building department would provide the live load for a roof in your area.
A lot of areas of the country it is 20 psf, my area is 30 psf because of our ground snow load.
Gary
covered patio dvp416 Interior Decorating 1 06-08-2012 04:24 PM
Patio Cracked & Sinking silvabul Building & Construction 3 05-04-2011 09:53 AM
Covered Patio Flooring rhbh Flooring 1 04-30-2011 06:56 PM
lighting a covered, enclosed patio (cross-posted in electrical) 1655graff Remodeling 1 11-21-2007 12:45 PM
lighting a covered, enclosed patio 1655graff Electrical 5 11-21-2007 08:06 AM
