-   -   Covered patio rafters (http://www.diychatroom.com/f19/covered-patio-rafters-190896/)
Daugela 11-24-2013 12:00 AM
Simple question.
What size rafters for a 17' span / 2' on center covered patio? I did a 10 foot span and used 268, but would a 17' require something bigger? 2x8?
No gable - flat porch.
thanks
tony.g 11-24-2013 06:29 AM
And the rest.
PoleCat 11-24-2013 07:04 AM
Snow loads are no issue. I would use 2X8 min. just so I could walk up there though.
joecaption 11-24-2013 07:18 AM
Where do you plan on finding 17' long lumber?
A standard would be 16' long.
PoleCat 11-24-2013 07:24 AM
Menard's has 18'. Bet they aren't that far west though.
Daugela 11-24-2013 09:27 AM
Yeah no snow loads in Phx. We did get record rain though this weekend. It's been raining for 3 days straight here.
Anyways, I could theoretically change my plans from 17 to 16 but would rather not. It's not a deal breaker. I haven't looked at any span charts yet.
Could the 2x8 be used if it's 16" - 0? That way I wouldn't be in the "minimum" area. Or I guess 2x10 at 2' - 0.
kwikfishron 11-24-2013 10:16 AM
199 Attachment(s)
Every lumber yard I've ever dealt with stocked 18 and 20' 2x's. It's only in the box stores I've seen length limited to 16'.
GBrackins 11-24-2013 11:16 AM
it depends on your code requirement for live load and the grade and species of wood selected. these span tables are from the 2009 International Residential Code:
http://publicecodes.cyberregs.com/ic...9_8_sec002.htm
Daugela 11-24-2013 08:07 PM
Im trying to figure these tables out and am having a hard time. I'm looking at Douglas Fir, NO snow load, live load 100p/sft. I can't get a span further than 9 feet for 2x10s. Makes no sense.
Surely I'm doing something wrong…
tony.g 11-25-2013 04:49 AM
Originally Posted by Daugela (Post 1271089)
live load 100p/sft.
Your live load won't be anywhere approaching 100 lbs/sq ft, unless you are using the roof to store your collection of vintage cars.
I wouldn't know your code requirements, but it will be much lower, if only for occasional maintainance, say 10-20 lbs/sq ft? Your dead load (ie the weight of the structure) will be quite low - maybe 5-10 lbs/sq ft.
2x10@2ft centres would be fine.
Daugela 11-25-2013 07:52 AM
A guy on here said 100lbs/sqft. His reasoning was so a person could walk on it for maint, etc…Made sense at the time. Now that you're mentioning it, that is way overboard.
Thanks for the input.
GBrackins 11-25-2013 12:38 PM
live load for living space is typically 40 psf, bedrooms are typically 30 psf. a call to your building department would provide the live load for a roof in your area.
A lot of areas of the country it is 20 psf, my area is 30 psf because of our ground snow load.
