Cover Slab If Not Going To Build For A While? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-01-2010, 10:21 AM   #1
Lost..
Rewards Points: 336
Cover slab if not going to build for a while?
I have heard that it is best to cover a concrete slab if you are not going to build on it for an extended period. I just poured a slab for a little building, and it will probably be this fall or winter before I save enough money to build the actual structure on top of it. Would it be best to cover it, and if I do what would be a good cover?
J S Machine is offline   Reply With Quote
Old 06-01-2010, 12:15 PM   #2
joed's Avatar
Rewards Points: 12,872
I don't see any reason to cover it. If the slab is fresh keep it wet for about a week to aid in curing. This is most important the first few days especially if it is hot and sunny.
Washer agitator/spinner turns one way, but not the other IckesTheSane Appliances 5 01-10-2009 02:53 AM
Carpet on a sloped concrete slab? slickracer Flooring 4 12-13-2008 03:08 PM
lifting up concrete slab ctudan Building & Construction 1 10-28-2008 02:44 PM
Can I set a cabin on top of mobile home slab? birchbarx Building & Construction 4 03-22-2008 06:06 PM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 12:50 PM
