Cover Patio Ideas - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-09-2012, 11:27 AM   #1
Cover Patio Ideas
I am needing some ideas for my patio. I want to do a pergola or maybe just cover the patio. The patio is 24 x 9 1/2. What would be the best option for me? Any help would be great! Thanks
fja1982 is offline   Reply With Quote
Old 07-09-2012, 11:40 AM   #2
Architect
Rewards Points: 150
What is that ledger board already installed at the top of the wall?
Looks like you are ready to put a pergola in already, unless there was some other purpose for that ledger?
jcarlilesiu is offline   Reply With Quote
Old 07-09-2012, 01:18 PM   #3
That board was there when we moved in. The owners took what they had with them....lame!
Old 07-10-2012, 03:54 PM   #4
bump?
Old 07-10-2012, 04:58 PM   #5
Architect
Rewards Points: 150
Sorry, didn't see you responded.
I would say go ahead and utilize what they left you (it was probably for that purpose before).
Verify how its fastened to the building to ensure that it can support a pergola, and if so then that is how I would use it.
With the front of the patio being 24' wide, I would recommend install some 4x4 posts and building a perimeter frame. From there, I would install the pergola boards across and overhanging the front.
Pergola's should have the boards running in the north and south direction to be effective in the spring and fall.
How you handle the pergola at the door is left to be seen, but I have some design ideas of course.
Just some suggestions.
rebuilding a patio cover ONEMORETIME Building & Construction 4 04-15-2012 09:29 PM
15' by 15' freestanding patio cover hdfxdwg1 Building & Construction 1 04-01-2012 02:10 PM
Ideas for replacing screened-in patio Lttlmichey Building & Construction 2 07-18-2010 10:22 AM
calculating slope for patio cover epdave Carpentry 7 01-21-2009 11:22 AM
Patio Cover - Need help/suggestions DIYer Building & Construction 7 02-19-2006 10:00 PM
