#1 |
Cover Garage Vents
Hi All,
First post here! I am preparing to sheet my garage walls with OSB and had some questions regarding vents in the walls. My garage is a detached garage with attached studio. The garage portion currently has three vents. One above the garage door, and two on the same outside wall... one about 12 inches off the floor and one on the other side the same wall at about 5ft high. My question is what to do with these vents on the wall. Can I just cover them up with the OSB? The Garage is going to stay a garage/shop. The ceiling is not going to be finished, just the walls. The ceiling will remain open pretty much (may close off 1/4 of it for storage) Any ideas would be great! |
#2 |
Super Moderator
Cover Garage Vents
I'd need to see pictures to be absolutely sure---but Those low vents can be closed up--all that is needed ore soffit vents and a vent or two on the roof.
New members: Adding your location to your profile helps in many ways.--M-- |
#3 |
Moderator
Cover Garage Vents
Give a call to your local B.D., as these vents were required to pass Code. In the '70-80's a high and low vent on opposite sides were installed to prevent carbon monoxide poisoning from auto exhaust. FHA required them as did many Cities around here. May not be needed now, always good to check........
If you do close them, air seal the inside osb from the outside air and moisture. Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
| The Following User Says Thank You to Gary in WA For This Useful Post: | oh'mike (01-31-2011) |
| Display Modes | |
| Insulation in Garage Attic ? | SaDan | Building & Construction | 2 | 05-09-2010 06:44 AM |
| Indoor AC vents..should I cover them? | StahlMaster | HVAC | 9 | 03-28-2010 01:18 PM |
| Attached Garage, No sub panel, seperate grounding rod | danocars | Electrical | 6 | 03-15-2010 06:27 PM |
| How to cover up ceiling vents in basement... | Goldglv | HVAC | 7 | 07-09-2009 09:27 AM |
| Electrical problem in garage | ginaca | Electrical | 10 | 04-19-2009 07:51 PM |
