Cover The Gap Around The Floating Slab? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-30-2011, 05:37 PM   #1
Cover the gap around the floating slab?
I have a 1.25" gap between the edge of my concrete floor and block wall in my basement (floating slab I guess). I noticed moisture in there so I got the idea to use spray foam to seal it. One weekend about 5 years ago we had terrible rain storms with inches of downpour. At one spot of that sealed gap water seeped into my basement...had a puddle about 3' x 5'. As soon as I began to remove the foam from the perimeter gap the water receded and I never had a problem since. I am in the process of installing a sump pit in the back corner of the basement (where the water seeped into - seems to be the low spot). I would like to channel the perimeter drain to the sump pit. I also want to "cap" that perimeter opening to avoid unnecessary moisture vapors from leaking into the basement. My walls are drylocked, all downspouts are channeled about 100' away from the house, good slopes in the landscaping. Any thoughts on how to cap that perimeter drain?
daveinpa is offline   Reply With Quote
How to cover a hole in a floor slab tomseeley Flooring 2 11-16-2009 12:14 PM
Cement slab touches buildings cbuisman Building & Construction 2 06-09-2009 10:24 PM
Suggestion for new sidewalk slab flyboy_ont Landscaping & Lawn Care 7 05-22-2009 11:15 AM
xps and t&g on cement slab? HABSFAN2006 Flooring 10 04-14-2009 07:28 PM
Washer agitator/spinner turns one way, but not the other IckesTheSane Appliances 5 01-10-2009 02:53 AM
