Countersink Concrete - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-24-2010, 09:48 PM   #1
Rewards Points: 260
countersink concrete
I need to countersink a bolt. It only needs to be countersunk 1/8in to 1/4. What type of tool or bit can I use to countersink concrete? The washer is about 1in in diameter.
Thanks in advance
bluefitness is offline   Reply With Quote
Old 12-24-2010, 10:35 PM   #2
Rewards Points: 558
Cobalt steel and tungsten carbide bits are designed to drill into most construction materials, including concrete.
epson is offline   Reply With Quote
Old 12-25-2010, 06:07 PM   #3
Rewards Points: 5,336
Does this need to be just a functional counersink or ascetically pleasing?
If just functional, drill a series of smaller hole around the bolt shaft and clean it up with a chisel.
If your drilling a lot of these, get a 1"+ masonary bit and use that.
Or use a grinder.
Ron
Old 12-27-2010, 09:55 AM   #4
Concrete & Masonry
Rewards Points: 620
A high speed electric or air powered die grinder with a carbide bit, along with a steady hand, can result in a fairly clean job.
jomama45 is offline   Reply With Quote
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 04:53 PM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 08:21 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
